My vehicle machine need help
Old Jul 8, 2023 | 12:25 AM
Foreign friends's Avatar
I am the owner of 16 . I bought 17 navigation and want to use Carplay, but an error will be displayed after inserting the SD card. Is there something wrong with SD? The seller said that this was the original SD card. How can I solve this problem?Thank you for your help
When I insert the SD card and turn it on
This is the SD card given to me by the seller
It’s so beautiful
Old Jul 9, 2023 | 10:06 AM
Noahdomani's Avatar
Check your head unit for the serial number. I believe it is on the top of the unit. I forget. But it will tell you if that is the original and correct card
Old Jul 9, 2023 | 03:29 PM
Hello, buddy, this is my car ID. Can you check if there is anything wrong with me?
Old Jul 9, 2023 | 03:35 PM
Noahdomani's Avatar
Look right under Nissan. The numbers don't match, that is not the original card.
Old Jul 9, 2023 | 04:03 PM
Hi Please forgive me for interrupting.You seem to be proficient in this. Can I tell from those details? Do you have any tips? I need to explain it to the seller and let him know why.
Old Jul 9, 2023 | 04:09 PM
Noahdomani's Avatar
Each heading and card are paired basically, you have to have a card with the exact same number. Your head unit is 25915 9DD1C. The card is 25920 9DD0C. They are not a match and won't work. I haven't had the issue but came across it when I was trying to update the firmware for the head unit
Old Jul 9, 2023 | 04:51 PM
Thanks,i think i found the preoblem.this SD card does not have Bose machine
