Blue Smoke, PCV and Valve Cover
Old Apr 6, 2024 | 05:46 PM
Les7311's Avatar
Been noticing a blue tailpipe smoke on remote start, like an oil burn-off for a few seconds, and almost daily.
weeks went by and decided to pull front 3 spark plugs. … not good!
Spark plugs Threadings glistening w oil, plus burnt porcelain.
ordered front and back VC online for under $90 and comes w everything ( gasket, seals, bolts and pvc), and new spark plugs from stealership.
also Replaced the VC-to-VC vacuum hose as a crack noticed.
surgery lasted about 3 1/2 hours.
culprit : stuck pVC valve.
Old Apr 7, 2024 | 04:18 AM
RickSmith's Avatar
I firmly believe that the PCV valve is neglected during routine maintenance, and easily forgotten. Until there is a problem, like you experienced, no one pays attention to the PCV.
My household has owned VQ35 Altima and Maxima since 2007. I use spray carb cleaner to clean the PCV every 25,000 miles.
Old Apr 7, 2024 | 06:27 AM
robtroxel's Avatar
Thanks for the report and I would bet others may see this issue.
Old Apr 7, 2024 | 10:02 AM
Les7311's Avatar
This video was followed ( not my first time doing this surgery). Identical to our Gen engine.
Old Apr 7, 2024 | 10:05 AM
Les7311's Avatar
my ‘11 has 330k miles and I beleive I replace the valve about 100k. Went and pulled the valve and this too was stuck.
🤜🏽cleaner worked….🤛🏽
Old Sep 21, 2024 | 02:25 AM
Bardamu's Avatar
Hi,
I had problems with PCV valve (bad idle, lack of power, etc.). I changed the PCV valve with second market and it improved but wasn't perfect. I only solved the problem completely when I put an OEM part.
PUT AN OEM PART, otherwise it will not work perfectly.
Old Sep 21, 2024 | 04:02 AM
RickSmith's Avatar
Bardamu, I agree 100% with you. OEM PCV valves are more expensive than no name aftermarket parts, but are worth the added expense.
Old Sep 21, 2024 | 05:22 PM
Les7311's Avatar
Rick and Bard,
the VC for my surgery came w the PVC. I went ahead and used it and noticed that if I had to replace it, the reach was not bad - close to the firewall w good real estate.
so far so good….
nishfish871
Nov 5, 2013 06:18 AM
hassanqadir
18
Nov 4, 2011 08:49 AM
hassanqadir
Jul 3, 2008 08:41 AM
paralyse
Apr 21, 2005 05:43 PM
Ladzio
Dec 24, 2004 09:21 PM
