Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
What size spacers do I use
Old Jul 12, 2006 | 04:45 PM
reliningmaxima's Avatar
Exclamation What size spacers do I use
I have a 2000 maxima lowered with s tech's and blues for now on 19's 8.5 ADR rims. I would like to know what would be the highest (mm) amount of spacer that I could put on it to eliminate the gap and have that flush look and not damage the fender or the tires with no rubbing (perfection is a biach) post links from where you got yours and how much and pictures if you have any spacers on your ride.... I heard H&R's have the best quality and fitting
Old Jul 12, 2006 | 06:18 PM
MaximaSE96's Avatar
Maxima Owner
measure and find out......i have 16.5mm H&Rs.....i milled mine from 20mm...but i did it to clear my brakes
Old Sep 22, 2006 | 03:11 PM
ReMyXe's Avatar
Spacers make the wheel come further out than the regular stock look right? or am I just sounding stupid?
Old Sep 22, 2006 | 03:41 PM
MorpheusZero's Avatar
Yes they do, and I'm not sure if that was a worthwhile post. =\
Old Sep 23, 2006 | 07:49 AM
BEJAY1's Avatar
Conecarver
Like Chris said you're gonna need to measure your clearance and find out. Both H&R and Eibach are very good quality. You didn't mention the tires your putting on those 19x8.5s and that'll dictate your fender clearance along with how lowered you are.
Old Sep 24, 2006 | 09:22 AM
VQuick's Avatar
Chassis Freak
If you decide to put spacers on the front as well as the rear, the front spacers should be 15 to 20mm less than the rear spacers. The rear track is that much narrower than the front track; something to do with the multi-link beam rear suspension.
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
