Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
thickness of good brake rotors
Old Jul 16, 2006 | 12:27 PM
yonjun's Avatar
My brakes are sqeaking and I know that my fronts are shot.
so I was checking the thickness of the brake rotors today (2001 i30) but it measured to be 26mm (front) and 10mm (rear). my front pads are shot, rear pads are still good.
and I mearured the brand new rotors(dura last from autozone) and they are 26mm (front) and 10mm (rear).
are my rotors still good? what % of life do I still have on them? or need to replace along with pads?
Old Jul 16, 2006 | 07:42 PM
Matt93SE's Avatar
STFU n00b!
if the rotors aren't severely gouged up or warped, then just install the new pads and call it a day.
Old Jul 16, 2006 | 08:11 PM
yonjun's Avatar
since I got the car used last year, I'm not sure when exactly the brakes were done. and I've put on 10,000km since.
I thought rotors need to be replaced as well but the thickness is same as new rotors I got as I mentioned above. so I was curious what's the minimum thickness of rotors for our cars. if my existing rotors are still good, I can replace front pads and return the rest of parts I purchased.
Old Jul 16, 2006 | 08:30 PM
MaximaSE96's Avatar
Maxima Owner
somtimes replacement rotors are soo cheap its worth it just to replace....but like matt said id they arent gouged or warped...new pads are all u need
Old Jul 17, 2006 | 08:02 PM
Matt93SE's Avatar
STFU n00b!
check your FSM in the brake section for the minimum thicknesses allowable.
Old Jul 18, 2006 | 01:01 PM
Larrio Motors's Avatar
Boss Chen Industries
IIRC, my rear brembo rotors said 8mm as the minimum thickness. Depending on how much a shop charges you to cut them and re-install, you might be better off buying new ones
Old Aug 17, 2006 | 07:25 AM
sdoow's Avatar
How were you measuring the thickness of the rotor?
Old Aug 17, 2006 | 08:50 AM
yonjun's Avatar
with mearuring tape
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
homeyclaus
Sep 3, 2015 06:15 PM
VQ'ed
1/4 and 1/8 Mile Racing
Aug 30, 2015 05:32 PM
RealityCheck
Aug 5, 2015 06:18 AM
