Drilled and Slotted Rotors and Noise
For everyone who has drilled and slotted rotors how do they compare with blanks with regards to noise? This is for the Cobra BBK setup and I plan on using Nissan OEM pads. I've read a lot and there are a lot of mixed comments I can't tell if noises are attributed to the pads, the rotors or both.
Originally Posted by maximamass
What kinda rotors do you guys suggest? I have owned a 2000 and a 2001 and I have gone through 4 sets of rotors already between the two cars. I am sick of replacing rotors!
2. maximamass...why have you gone through 4 sets of rotors? Might I ask if you're using Nissan or OEM replacement (i.e. autozone/pep boys/etc) basic pads?
to Irish's 1. commentAfter having both x-drilled/slotted iRotors and switching to Brembo blanks, I find very little different between the two. I did notice that my iRotors did begin to crack around the drilled holes, so to those that have this type of rotor, make sure you periodically check for cracks (on both sides).
How do you figure out if its the front or rears?
So, now I have some extra front rotors sitting around that are still good.
How many posts must you have before you can start a post or privately message somone?
Also,
How often do wheel bearings and tie rods go on these cars?
Also,
Apr 16, 2020 05:15 AM
