Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Camber bolt/plate discussion
Old Jul 21, 2006 | 06:57 PM
97SEdriver's Avatar
this place is dead
Irish and myself took this thread into the realm of this forum...so it might as well be discussed here in more detail.
http://forums.maxima.org/showthread.php?t=482515
Old Jul 27, 2006 | 02:51 AM
97SEdriver's Avatar
this place is dead
wow.......I really thought this would generate some discussion in this forum, guess everyone has already said what they're going to say about it.
Old Jul 27, 2006 | 09:25 AM
michaelnyden's Avatar
my progress camber bolts have never shifted...and they are only tightened down to 85 ft.lbs. IIRC...I managed to get -2.3 degrees on each side with them...
Old Jul 27, 2006 | 01:03 PM
BEJAY1's Avatar
Conecarver
I've used both SpecProd and Progress camber bolts and they've never slipped.
Old Jul 27, 2006 | 04:57 PM
Jon94SE's Avatar
Camber Bolt
The previous owner of my car hit a median and the wheel pretty much exploded. After I bought it, the front driver side was making what sounded like a bad wheel bearing sound. I've also heard that if your camber bolt comes loose that it will cause that noise. I replaced the bearing and when I took the strut off the bolt seemed tight but after getting all back together it's still making noise. could it still be the camber bolt moving around?
matts95max
Apr 23, 2025 10:44 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
wingnut2006
Sep 19, 2015 06:13 AM
