Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Illumina & Progress: Rear Passenger Strut Noise
Old Sep 11, 2006 | 06:26 AM
Pri63's Avatar
I've had this setup for a while now with a Addco RSB. I love the setup but whenever I have load in the rear two passengers, for example, and I go over humps in the road, moderate changes in the slope of the road that cause the struts to decompress and then compress, the right rear strut makes a loud rubbery noise. I've tried many things...adjustments to RSB, took the rear struts to stock and still...the problem exists. Any advice/suggestions?
Old Sep 12, 2006 | 05:28 AM
Kevlo911's Avatar
Kevlo for President
Could it be the bumpstops?
Old Sep 13, 2006 | 01:40 PM
Stalldaworld's Avatar
i get a moderately loud thunk/ bang in the right rear, doing the same thing u described. illmina,progress,progress rsb...any insight on this matter is def apriciated.
Old Sep 14, 2006 | 04:24 AM
kbmaxima's Avatar
+1 ONLY the rear passenger right? so weird
Old Sep 14, 2006 | 04:38 AM
DrKlop's Avatar
Driving is the next best thing
check the bomp stops or the shock mounts...
Old Sep 14, 2006 | 06:08 AM
VQuick's Avatar
Chassis Freak
If the strut shows no evidence of damage (leaking oil) then I would bet it's a rubber part of the suspension. It would be worth replacing all the rubber parts in both rear suspension assemblies.
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
95Maxi
35
Sep 2, 2015 10:37 AM
george__
Aug 18, 2015 07:06 PM
