Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
everybody with ground controls...
Old Sep 21, 2006 | 06:40 PM
99black5spd's Avatar
Exclamation everybody with ground controls...
i would like to see an installed picture of the front and rear setups. i have these installed on my max with agx's but i just want to see if i had done it right. because when i lift my vehicle up on the lift the springs arent touching the top strut mount. i have the gc set all the way down on the sleeve. please let me know if i did this wrong or if i just need to put the spring a lil higher on the sleeve. thanks
Old Sep 21, 2006 | 09:39 PM
DrKlop's Avatar
Driving is the next best thing
post a pic man!!
Most likely you just have to move the spring perch a little higher...
Old Sep 22, 2006 | 11:29 AM
MrDicks95SE's Avatar
Offset Is Everything.
you mean the spring and tophat arent touching the upper mount? i believe thats normal while the chassis is lifted and the wheels hang. its a very small and short spring. if the spring perch is set all the way down, youre most likely riding on the bumpstops all day, given that they are in there. id recommend lifting it up or getting some shortened struts, ie: Koni Yellows, to get that needed suspension travel.
Old Sep 28, 2006 | 06:55 AM
cardana24's Avatar
Blown
when my car is lifted they do not touch the top spring perch. I am pretty sure this is normal.
Old Sep 28, 2006 | 05:22 PM
DrKlop's Avatar
IMO everything should be tight even then the car is lifted.
Old Sep 29, 2006 | 04:58 AM
Nealoc187's Avatar
SLOW
no, it shouldn't
what the OP is describing is how they are supposed to be.
Old Sep 29, 2006 | 05:33 PM
DrKlop's Avatar
no, it shouldn't
It's just not safe to drive around like this. The top few coils can simply slide to the side while he is driving, which will result in some very unpleasant experience. BTW, I know for sure that something like this would never pass TUV regulations.
Old Sep 30, 2006 | 10:28 AM
z32drifter's Avatar
Sounds like you need "helper springs" ... does GC offer a helper spring setup??
pktaske
Sep 4, 2015 08:40 AM
