Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
HELP..ASAP Trying to remove pistons on Z32 calipers?????
Old Sep 23, 2006 | 03:19 PM
Mxrider52's Avatar
I support for what?
Ok guys I got me some Z32 calipers that need new seals. I took off all 4 retaining clips and I put air through the brake fluid line hole. I got one piston to pop finally(scared the shizzle out of me) But now how do I get the other 3 out??? I am stumped.
Old Sep 23, 2006 | 04:09 PM
Dubbya's Avatar
VK56 Inside
hehehe. You need to use various clamps and blocks of wood. They pop out one at a time. Then you need to reseat the one that pops out just far enough in to where you can still pull it back out some how with out air. Once you have it seated like that then you need to find a way to make it stay in place. Like a clamp. Took me a minute to figure the first one out but the second one was easy.
Old Sep 23, 2006 | 04:15 PM
Mxrider52's Avatar
I support for what?
Alright Thanks. You would think out of all the people doing BBK and what not. There would be atleast a write up on how to rebuild Z32 calipers. Not even a write up or anything on 300zx forums. Crazy
Also how should I go about removing the spray paint the previous owner sprayed on? I have some spray on paint stripper but how would I do it? Like should I remove the paint before I remove the pistons to put new seals in?
Old Sep 23, 2006 | 04:18 PM
Dubbya's Avatar
VK56 Inside
When I did mine I removed all the old pistons and seals, and then prep'd them for paint. You just need to make sure you really clean out the piston bores and the fluid veins before you rebuild them. If you are going to spray paint them I would recommend finishing the rebuild before spraying. This way no over spray gets in the bores. I used a dremel with a wire brush to clean off my calipers.
Old Sep 23, 2006 | 04:19 PM
Dubbya's Avatar
VK56 Inside
Also most people dont rebuild them. They just buy the rebuilt ones from Autozone.
Old Sep 23, 2006 | 04:28 PM
Mxrider52's Avatar
I support for what?
How do I go about cleaning out the fluid veins? Sorry for the stupid ques but I have never done anything like this before. I was going to purchase the rebuilt ones from autzone but they costed more then it was to rebuild them.
I am going to buy the G2 paint and paint them with the brush so I dont get paint in places it doesnt need to be. Unless spraying them with just hi temp paint is just as good? I know hi temp fades over time but dont know about G2. I will probably cheap out and spray paint them.
Even the 300zx FSM is limited on how to remove the pistons. Just shows how to remove one piston. Says push out piston with compressed air and that it.
Old Sep 23, 2006 | 04:34 PM
irish44j's Avatar
retired moderator
I pulled the pistons out of mine using a some plumber's pliers with rubber caps on the ends (so not to scratch anything), and just twisted them while pulling outward...came out no problem.
Old Sep 23, 2006 | 05:28 PM
Mxrider52's Avatar
I support for what?
Cool I will try that. I have some of those pliers that you slip the rubber cover over. Air and brake fluid just dont mix.
Old Sep 24, 2006 | 11:10 AM
Dubbya's Avatar
VK56 Inside
To clean out the viens I just sprayed a bunch of brake parts cleaner in where the bleeder goes. Simple as that. GR2 paint is good stuff. Ive had mine for 2 years and there is no signs of fading.
my03maxima
Jul 28, 2024 07:40 AM
Apr 16, 2020 05:15 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
