Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Uneven brake wear
Old Oct 15, 2006 | 05:57 AM
speed racer's Avatar
Uneven brake wear
I just changed my pads this weekend and I noticed some really signaficant brake wear.
This is the Driver Side (Front)
This is the Passenger Side (Front)
From the pictures you can see the driver side is worn down real bad compared to the passenger side. On both sides, the bottom main pin on the torque member had rust and was seized. I was able to get the Driver side out and regreesed, but the passenger side is stuck. The caliper didn't take too much effort to push in. What could be the reason for the pads wearing like this?
Old Oct 15, 2006 | 01:08 PM
irish44j's Avatar
retired moderator
bad piston in one of the calipers, perhaps?
The right piston might not be retracting all the way and slightly dragging.
Old Oct 15, 2006 | 01:44 PM
its the bottom caliper pin on both sides. The driver side was easy to get out even with the rust but the passenger side is siezed really bad. I'm going to try to knock the pin out again. If not its off to the junk yard for a TM. By the way those pads have 18,000 miles.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
