Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
installed tokico blues, loud grinding noise
Old Oct 19, 2006 | 08:42 PM
Mad_A's Avatar
I just put in some used tokico HP struts (blues) and Tein s tech springs on my car, and now I'm hearing this loud grinding noise from the front passenger side when I turn the wheel in either direction. I recorded the noise from the inside of the car:
http://www.adamaggour.com/maxima/noise.mpg
Has anyone heard this before? Any ideas? front passenger side is the only one with this problem, the others are perfectly silent. The mechanic said the strut was 'bent', I just want to make sure no one has run into this in before and that its not due to something else that is easier to fix/replace.
Any help is appreciated!
Old Oct 20, 2006 | 12:18 AM
Batxel's Avatar
blah
http://forum.maxima.org/showthread.php?t=381299
Old Oct 20, 2006 | 03:16 AM
Mad_A's Avatar
Thanks for the link, but I had send that video of the noise to someone who had suggested the exact same thing, that it was the bearing, but after hearing it he said it didn't sound like that was the problem.. I'll double check tomorrow., err later today that is
Old Oct 24, 2006 | 11:22 AM
super6's Avatar
If The Noise Only Started When U Installed The New Set Up, It May Be The Way The Spring Is Seated, Then Again That Is A Bit Loud For A Spring???
Old Oct 24, 2006 | 11:37 AM
Mad_A's Avatar
I went ahead and bought a new strut, hopefully that will fix it, since the mechanic told me nothing is wrong with my mount or bearing...
Old Oct 24, 2006 | 02:20 PM
super6's Avatar
were the ones u had new or used? really doesnt sound like a strut issue at all.
Old Oct 24, 2006 | 02:37 PM
Mad_A's Avatar
The ones I had were used. I took the car back to the mechanic to have him look over bolts, the strut mount and the bearing.. so I had no other option to try really... he was saying the part that goes into the strut mount was bent..
Matt93SE
May 24, 2019 02:58 PM
maxinout93
Oct 27, 2015 01:29 PM
95Maxi
35
Sep 2, 2015 10:37 AM
carlosvq30
Aug 17, 2015 11:32 AM
egali045
Aug 16, 2015 01:19 PM
