Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Problems with brake bias (BBK)?
Old Nov 2, 2006 | 01:27 PM
NCSU_MAX's Avatar
Maximoneypit
Ive heard of a few guys saying that the addition of a BBK up front is eating up their rear calipers/rotors due to brake bias. Is this a major issue for most people and if so is there a way to alleviate it? thanks guys,
Grant
Old Nov 2, 2006 | 02:26 PM
Chunger's Avatar
My other car is a Hybrid
Not with my original 12.2" Fastbrakes or my modified 13" Fastbrakes;
Nor do I have that problem with my AP Racing Kit either...
All those kits have a greater piston surface area than stock (3.14 in/sq) at least on 4th Gen. That coupled to a greater torque arm radius of the larger rotors...
Old Nov 2, 2006 | 05:27 PM
NCSU_MAX's Avatar
Maximoneypit
Ok cool, I just got some Z32 aluminum 4 piston 30mm calipers and 13" RTP slotted rotors so hopefully they'll work well. Ive heard good things about the setup but just trying to get several opinions, thanks!
Grant
Old Nov 2, 2006 | 07:57 PM
irish44j's Avatar
retired moderator
I haven't had that problem.
I think that is only happening to some of the 6th gen guys who have the electronic brake proportioning system or whatever it's called....the sensor "reads" the brake bias wrong with a BBK for some reason, apparently.
Old Nov 2, 2006 | 08:56 PM
!PrjctMax!'s Avatar
No, it's because the car is lowered. Kam said that when he had Progress springs all around the rear brakes would lite up a lot, but when he put the OEM springs in the rear and did the same test, both front/rear lit up evenly.
The sensors think that there is added weight in the rear (as in passengers or cargo) and therefore it applies more braking for the rear.
Dan
Old Nov 2, 2006 | 09:45 PM
86maxima96's Avatar
I Broke OT
Grant
i'm new to the abbreviation 'RTP'. what does that mean?
Old Nov 3, 2006 | 06:21 AM
!PrjctMax!'s Avatar
Good question, main point, it's just another company that makes rotors.
Old Nov 3, 2006 | 10:31 AM
86maxima96's Avatar
I Broke OT
ah, thanks
Old Nov 7, 2006 | 09:12 PM
kamski's Avatar
.org extraordinaire
Dan
Exactly, i couldnt fakin believe it my self till I tried the test. Frig even the Techs at Nissan Shop are wondering how the hell that EBD (electronic brake distribution) system works. I read the FSM and there is a proportioning valve but I cannot figure out where exactly it is and how to modify it.
Kam
Old Dec 1, 2006 | 11:12 AM
shawndon's Avatar
Grant
Where did you get that setup from??
Old Dec 1, 2006 | 01:17 PM
NCSU_MAX's Avatar
Maximoneypit
pieced it together from the 4th gen classifieds
Old Dec 2, 2006 | 03:04 AM
shawndon's Avatar
I'm in the process of trying to find a setup now but. I just want to make sure it is quality. Is rotora and power slot any good???
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 16, 2015 07:20 PM
bbsitum
Sep 11, 2015 04:55 PM
slowlifer
Sep 8, 2015 05:53 AM
