Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Such thing as durable suspension???
Old Dec 6, 2006 | 11:56 PM
NISMOPower's Avatar
Hey guys, I currently have AGX/Sprints, I have a blown front left strut and is looking for new suspension. This car is driven on a track that is fairly tight and rough pavement. Is there even such thing as durable suspension???
I have been thinking of Konis with the best handling spring set up there is or coilovers. Does anyone know if coilovers can take more of a beating or is it worth the extra despite rebuilds??? Does strut/spring setup even compare to coilovers?
Chris
Old Dec 7, 2006 | 12:28 AM
Poowill's Avatar
Koni's are definately a better shock. But i would assume considering the stiffer springs, one piece components, and very popular for track purposes that coilovers are going to be a lot more durable. I have ksports and they don't even compare to a spring/strut combo. Much stiffer and even smoother in some cases..
Old Dec 7, 2006 | 08:08 AM
97SEdriver's Avatar
this place is dead
I thought AGX had lifetime warranties?
Old Dec 7, 2006 | 09:01 AM
Matt93SE's Avatar
STFU n00b!
no warranty against bottoming out the track.
what are you using for bumpstops? how often do you bottom out the suspension, and how hard?
Old Dec 7, 2006 | 02:01 PM
97SEdriver's Avatar
this place is dead
well, I wasn't telling him to tell them that he tracks his car
Old Dec 11, 2006 | 02:00 PM
RA030726's Avatar
I'm nutty for Nissans
Go with 3rd gen Koni reds up front, 4th gen Koni yellows out back with Ground Control coilovers. If you want to get low out back get B14/B15/P11 rear adjustable (agx, koni, etc.) shocks for some added travel.
Old Dec 18, 2006 | 03:33 AM
dko's Avatar
dko
duck and cover
KYB will honor the warranty if you tell them your AGX's were paired with H&R's for daily driving
Old Dec 22, 2006 | 09:30 PM
MaximaSE96's Avatar
Maxima Owner
only way to go....even if u just use all 4th gen Konis u will not regret it
Old Dec 23, 2006 | 07:33 AM
d00df00d's Avatar
Old enuf to pick his own gears
If you're looking for something you can just slap in and forget about, Konis are your only option, especially if you have more than a moderate drop. Konis with Ground Control sleeved springs (they're not technically coilovers) would be a great combination -- definitely one of the best you can get without totally breaking the bank. The only disadvantage is that you can't adjust ride height without affecting suspension travel with that combo. But if you're looking for something durable, this is as good as it will get.
Full coilovers always give you the best handling with a decent ride, but as you mentioned, they will occasionally need to be rebuilt. If you're driving on a lot of rough roads, figure on one to two rebuilds/damper replacements a year (at $75-$150 each, depending on the manufacturer) to be safe.
If you want a good, reliable coilover kit, you need Progress or Ksport. Both companies make good stuff and have great customer service and short turnaround times. Progress has better dampers that are slightly more durable and cost half as much to rebuild; Ksport is a little behind in those departments but gives you WAY better adjustability -- you can change height without affecting suspension travel, and you can add preload to your springs to corner-weight your car and fine-tune your handling.
Any other company (Tein, D2, JIC) will be more expensive and/or difficult to get rebuilds on than Progress or Ksport.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
foodmanry
Sep 24, 2015 12:02 PM
carid
Sep 17, 2015 05:00 AM
Violator
Sep 9, 2015 10:14 AM
A32goldylocks
Sep 2, 2015 06:39 AM
