Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
All Parts Needed For Full Major Suspension Rebuild?
Old Jan 10, 2007 | 12:29 PM
PharoNDmist's Avatar
I'm looking to upgrade my suspension all around and wanted to get everyones input and advice as to what would be needed. I'm fairly new to the adavance suspension modifcations and wanted to know what would be needed besides Coilovers, sway bars, bushings Sub-frame connectors, etc. to build the ultimate suspension setup? All advice is welcome, please no flames.
Thank you for your time and advice
-Will
Old Jan 12, 2007 | 08:00 PM
Bump...........
Old Jan 16, 2007 | 04:14 PM
Tsukuba_Circuit's Avatar
What's your budget? What are your plans for the car after suspension mods? Street only, Street/Track or Track only? What are you looking to achieve out of the suspension mods? How are the condition of the roads in your area?
Old Jan 18, 2007 | 06:02 PM
Well, I decided to its time to upgrade to coilovers(ksports most likley) and I 'm looking to do a street/ Track setup.I'm already boosted and really want to tighten and soildify the suspension up all around and just not with coilvers. Budget is between $1500-$2100. I'm in Long Island NY so depending on where I go, the road conditons vary, but for the most part its decent
Old Jan 18, 2007 | 06:41 PM
SNOMAX's Avatar
PM me for LCA's!
I did the same thing, this is what I replaced:
Axles from Raxles
tie rod endlinks
inner tie rods
sway bar endlinks
lower control arms (this covers the ball joints and bushings)
I also recommend energy suspension bushings for the sway bar end links and the sway bar frame mounts.
And if you don't have it a strut tower brace get one, they are dirt cheap.
I already had tokico illuminatas and springs. So, if you go with coilovers, you will have that part covered as well. You can get the energy suspension bushings from Brian Cattman.
-SNOMAX
Old Jan 19, 2007 | 04:50 PM
Cool, How much of a diffrence did you feel when it all was done?
Old Jan 19, 2007 | 06:46 PM
SNOMAX's Avatar
PM me for LCA's!
Quite a bit. I spent about $900 on the whole suspension and it was worth it.
Old Jan 20, 2007 | 11:07 AM
MaximaSE96's Avatar
Maxima Owner
Custom Ground Controls with Koni Yellows and Camber plates......ES Bushings all around(sway bar...End LInks, Control Arm, Motor Mounts.......Custom Sub-frame connectors....Rear Sway Bar
vingodine
45
May 21, 2016 12:46 PM
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
Team STILLEN
Aug 10, 2015 04:29 PM
