Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
For those running Z32 brakes (milled rotors)
Old Jan 21, 2007 | 09:46 PM
MorpheusZero's Avatar
How do you like them? How's the pedal feel, modulation, etc?
And does anyone know the brake balance with this setup and stock rear brakes (calculate it)?
Old Jan 22, 2007 | 05:25 AM
MaximaSE96's Avatar
Maxima Owner
IMO even though I dont have them.....this is my theory.....pedal feel is good....but the fact that that are 8mm smaller than stock brakes kinds of makes them a lil pointless.....sure the width helps with cooling bacause they are like 4mm wider but ur better off with Matts or Jeffs BBKs....the rotors are wider than stock and larger diameter.....now if u get Skyline R32 calipers they are 32mm wide and 16mm larger diameter than Z rotors....they would still need to be milled 4mm off the radius but they would be bigger than Z and Maxima brakes but a lil but...288mm(still fitting over your wheels) over the 272mm Zs would end up being after milling...280 is stock...
http://www.courtesyparts.com/Merchan...nismo_gtrbrake
i have been doing GOBS AND GOBS of research on rotor sizes and calipers llately
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
crazyespn
Sep 3, 2015 01:30 PM
A32goldylocks
Sep 2, 2015 06:39 AM
