What is the difference in GC's Tokico and KYB?
I am thinking about changing my strut set up on my Ground Controls. I would like to know what the difference in the GC's is, since they are sold for specifc applications. I am thinking about switching from AGX's to Illumina's. Anyone know?
Originally Posted by d00df00d
AFAIK the only difference is in the inner diameter of the sleeve. I could be wrong, though...
If that is the case do you know which struts are bigger? The reason I ask is because if the sleevs I have will fit over the Tokico's then that will work, because I wrapped mine with duct tape instead of using the rubber inserts, so I can just wrap more/less tape to make them fit snug.
Kyb front stuts can be adjusted on the top while the rear struts you have to adjust them by going under the car. Somebody correct me if I'm wrong on that. The Tokico are adjustable on the top.
doctorpullit
Dec 12, 2015 09:39 AM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
maxima-junky
Oct 7, 2015 06:13 PM
