Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Illumina owners, quick question... please
Old Feb 8, 2007 | 04:33 PM
OOmaxSE's Avatar
I asked this question in the 5th gen suspension thread but nobody has confirmed this and not many chime-in there. I figured there are more Illumina owners (4th and 5th gens) as well.
Here's a very simple question for you Illumina owners:
Can you keep dialing the settings to the right (or left, doesn't matter) from 1-5 and then back to 1 (without going counter)???
I did that to mine but I wasn't sure if it was normal. Basically, I can keep twisting the ****/flathead dial to the right and it will continue to go even from 5 to 1 (when twisting clockwise). So there are no "locks" between the jump from 5 to 1?
Thanks in advance!
Old Feb 8, 2007 | 04:45 PM
The Law's Avatar
I R The Law
I've only turned mine to 5 and stopped.
Old Feb 8, 2007 | 08:16 PM
irish44j's Avatar
retired moderator
IIRC, the instructions to the strut state that all adjustments should go clockwise 1-5-1 and so on...
Old Feb 9, 2007 | 08:21 AM
OOmaxSE's Avatar
In that case I shouldn't be worried. I'll double check that but basically it's saying to only dial clockwise. For example, going from 4 to 3 you'd have to dial through 5-1-2-3.
Old Feb 10, 2007 | 05:43 PM
Geoff's Avatar
I wondered the same thing when I installed mine. Would continuous clockwise rotation put the strut at a hypothetical level 6? but if it goes
1-2-3-4-5-1...then i guess not?
Old Feb 12, 2007 | 01:18 PM
ThurzNite's Avatar
mine doesn't have a stopper
Jae
Old Feb 13, 2007 | 07:54 AM
OOmaxSE's Avatar
OK, thanks. I read the instructions again and it shows half a circle tracing the outside of the strut rod (at the top where you dial) with arrows on both ends. So no signs of "only clockwise dialing." I wonder if jumping from 5-1 or vise versa hurts the struts, then?
doctorpullit
Oct 28, 2019 10:58 PM
D Mason
Jun 21, 2016 04:43 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
bernyp
Oct 2, 2015 10:10 AM
