Can we use 350z Brembo Calipers?
As the title states, can we use the OEM Brembo's from a 350z? If so what modification is nessarry. Can we use the rear brakes as well?
Thanks.
Thanks.
you can use anything you want if you have the correct relocation brackets made for it.....they do not bolt-up directly though...offset is wrong.
why not just use the z32 calipers with matt's or jeff's kit? That is more than enough brakes for the maxima (trust me, I know).
Speed if you got a line on a set for cheap, hook me up for my G35
But for your case, no, it's not a direct bolt up. I suspect the rotor offsets are okay. But you will probably have to shave the rotors down a few mm.
Rear? Not sure. If the Z uses an internal drum like the maxima, you might have a chance. You will probably have to do the same shaving thing as the front.
Irish. Since the mounting bores are so close, I don't think a bracket can be made. At least no easily. I suspect the caliper will have to be offset higher or lower.
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
imported_Nismo_max
Sep 21, 2015 07:24 PM
