Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Can you use old pads on new rotors?
Old Mar 8, 2007 | 04:47 PM
soundmike's Avatar
Very sound, Mike
I was always under the impression that's the way to go, but the instructions on my Brembo blanks suggest i use new pads with the new rotors from the get-go.
Has anyone encountered problems with old pads and new rotors?
Thanks!
Old Mar 8, 2007 | 07:23 PM
!PrjctMax!'s Avatar
IMO, if you get new rotors, you might as well just get new pads...about $120ish more. If your previous rotors were 'warped," then it's most likely that your old pads have many grooves in them and might screw up your new rotors, if they seem flat, and have a good thickness left to them, then sure I guess you could keep them.
If you want better braking performance just get new pads!
Old Mar 9, 2007 | 03:54 AM
soundmike's Avatar
Very sound, Mike
Good point. About 3 months ago, when i last re-greased my pads, the pad looked flat and fine with plenty of life left. I think the issue i have on my rotors may have been a bad combination of those pins sticking and me using Axxis pads in the past.
My rotors went from nice and shiny to groove-city in a short time when i still had the Axxis. The rotors actually feel smoother now that i have the Hawk's. I'll check on it again and see if it's worth re-using.
Thanks for the response, as always!
- Mike
Old Mar 11, 2007 | 09:42 AM
igzy's Avatar
I Know Kwaliti
I reused mine last time I did the rotor replacement, there was a lot of meat still left so I just roughed them up with some sanding paper put back on and of it went... This was about 20-25K ago and no probs since...
Old Mar 11, 2007 | 10:31 AM
BEJAY1's Avatar
Conecarver
I too replaced just the rotors but scuffed up the pads nice and clean w emory cloth before re-installing. Seemed to rebed just fine.
Old Mar 12, 2007 | 08:00 PM
lil humungus's Avatar
Thats good info. I was just wondering about this over the weekend.
Old Mar 13, 2007 | 05:02 AM
soundmike's Avatar
Very sound, Mike
Very cool. Thank you, all, for the responses!
On a slightly different note, after checking my old Powerslots over the weekend - i noticed that these are rebranded Brembo's. The odd thing is the box said they were "Centric" rotors.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
Socalstillen
Sep 26, 2015 12:01 PM
A32goldylocks
Sep 2, 2015 06:39 AM
