Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Droping Car With Mixed Brands?
Old Mar 21, 2007 | 07:03 AM
Brukaz's Avatar
I like the stance the s-tech has when it's dropped but I dont want it to be that low because of my lip kit. I was thinking of leaving my eibach springs in the back and putting progress springs in the front. That would give me a 1.7"/1.3" drop. With that drop the difference between the front and the back would be 0.4" which is the same difference with the s-techs just not as low, so I should get the same sort of stance that the s-techs would give and I still have room to put the lip kit on without having to worry about too much scraping.
Do you think that's a good idea :?:
Old Mar 21, 2007 | 09:26 AM
Kevlo911's Avatar
Kevlo for President
No problem with mixing... But you might want something higher in the front, I went from Progress to H&R because of my lipkit. But if your wheels/tires are bigger than mine then you will have no problems. I had 18" rim with 40height tires.
Old Mar 21, 2007 | 11:00 AM
Brukaz's Avatar
I got 245/40/18
Old Mar 21, 2007 | 12:07 PM
Kevlo911's Avatar
Kevlo for President
Originally Posted by Brukaz
I got 245/40/18
Then depending on your area you might still scrape a lot with the progress, hell I still scrape with the H&R's haha.
Old Apr 2, 2007 | 11:49 AM
sooner02r1's Avatar
I've got progress in the front, maxspeed in the rear (which are about the same drop as H&R) and it looks perfect. Exactly the same wheel gap front and rear. I also have a stillen lip on the front. I have 5" of ground clearance in the front. I've only had it on for about a week but I haven't scraped anything yet, just be careful. It looks awesome.
Old Apr 4, 2007 | 04:17 AM
d00df00d's Avatar
Old enuf to pick his own gears
If what you're going for is a certain look, there is no problem with mixing brands.
Lakersallday24
Jun 16, 2019 01:35 AM
PH98I30
19
Jun 13, 2016 02:38 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
