Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Vibration on throttle, help me diagnose the problem
Old Mar 26, 2007 | 07:47 PM
StrongIsleMax's Avatar
I am getting a high frequency vibration when I input anymore than cruising throttle. The vibration is very slight, high frequency, almost a rumble. This occurs in any gear between 2k-2.7k rpms. I checked the wheels bearings by jacking up the car and looking for free play, but found none.
I have a 2001 5-speed on BC coilovers at "progress" height. 155k miles.
I have never changed any suspension component, except for springs/dampers and front wheel bearings at 100k.
What could be causing this vibration?
TIA
Old Mar 27, 2007 | 09:30 AM
03MAXTNR's Avatar
I believe i have the same issue as you
Old Mar 27, 2007 | 03:28 PM
z32drifter's Avatar
Check your inner cv joints, they can casue vibration on throttle.
Old Mar 27, 2007 | 03:54 PM
nismology's Avatar
Old Mar 28, 2007 | 07:52 PM
I didn't get a chance to jack up the car and take a look. But, the vibration is much, much more prevalent when 1/4 + steering lock and mid-heavy throttle input. Does this make the problem easier to diagnose?
Old Mar 31, 2007 | 07:05 PM
I checked, and you guys were right, I have a torn inner CV Joint boot. There was some grease on the Oil Filter from the torn boot. The grease contains some metal shavings. Is it worth it to just change the boot or just replace the entire axle.
Thanks,
Old Mar 31, 2007 | 08:30 PM
z32drifter's Avatar
Just replace the axle, if you replace the boot it will not solve your vibration issue.
Old Apr 16, 2007 | 04:59 PM
97maxdaddy's Avatar
ya I had same problem. just changed all axles.
Old Apr 17, 2007 | 09:14 AM
Thanks everyone!
I changed my passenger side axle with a unit from Raxles and the problem is solved.
alahjahwan09
18
Sep 21, 2015 09:12 PM
bumpypickle
Sep 20, 2015 08:22 AM
Bonka
Sep 14, 2015 11:18 PM
Maxxx10
Sep 13, 2015 03:16 PM
thenewguyy
Sep 12, 2015 11:12 AM
