Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Overheating rotors & pads
Old Mar 30, 2007 | 04:34 PM
Pri63's Avatar
I replaced my rear rotors and brakes a week ago and today i'm coming off of the highway after about 80+ mph driving and I smelled brakes and saw smoke coming out of the my right rear wheel. I guess I didn't compress the piston enough. What damage have I done...it's not as easy as just taking it all apart and pushing the piston in further is it?
Old Mar 30, 2007 | 05:00 PM
Greeny's Avatar
¯\(°_o)/¯
Not likely,if you didn't compress the caliper piston enough,the caliper wouldn't even clear the pads enough when you reinstalled the caliper...
You either have a frozen caliper[needs to be replaced] or one or both of the slide pins are frozen[rusted]...If it is a rusted slide pin,you can use some pliers to remove the pin,then use a drill/w drill bit of the same size as the slide pin hole to remove the rust-n- junk from the slide pin hole.....Also,use sandpaper or a wire wheel to remove the rust from the pin itself..Regrease the slide pin hole/slide pin/reinstall pin/all other crap...
Old Mar 30, 2007 | 05:19 PM
Greeny's Avatar
¯\(°_o)/¯
Oh,btw...The pads/rotors should be fine,getting them hot for a few miles shouldn't hurt them...
Old Apr 1, 2007 | 07:20 AM
samito's Avatar
check your emergecy brake cable and see if it is releasing properly--had the same problem
Old Apr 19, 2007 | 08:52 PM
xfrodobagginsx
I did that not too long ago...
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
Socalstillen
Sep 26, 2015 12:01 PM
A32goldylocks
Sep 2, 2015 06:39 AM
