Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Stillen RSB spacers
Old Apr 21, 2007 | 03:02 PM
wootwoot's Avatar
Stillen RSB spacers
I recently picked up a still RSB and was going to install it but after going over the instructions I do not have the ebrake cable spacers. Where can I pick up a set or something else that will get the job done?
Old Apr 21, 2007 | 03:25 PM
asta4's Avatar
I had the same problem. Just made my own with some aluminum tubing. I cut them to the correct length and drilled out the center to right diameter. If you don't have the spacers you might also need the longer bolts that go with the spacer. I followed this how to:
http://www.greghome.com/Greg's%20Garage/2002MaxSE/StillenRSB.htm
Old Apr 21, 2007 | 04:56 PM
Dan5.5's Avatar
Hey,
Just go to OSH if there is one near your area.
Just got some spacers like 2 days ago.
Old Apr 29, 2007 | 09:48 PM
wootwoot's Avatar
I have looked near and far and can not find any spacers, can someone help?
Old Apr 30, 2007 | 07:14 AM
1FSTMAX's Avatar
I have a set of 2 spacers and 2 bolts left over from a stillen rsb.. Let me know if you want them.
Old May 14, 2007 | 11:43 PM
aznprid972's Avatar
You can probably get away with a few washers from Home Depot. I would think they would have spacers as well.
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Stagnet04
Sep 14, 2015 11:28 PM
