Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Bad wear on inside and outside of front tires
Old Jun 10, 2007 | 04:53 PM
paemt6220's Avatar
I have a 4th gen with a basicly stock motor. Falken Hanabis with 245/40/18 toyo proxes 4 tires.
I get alot of tire spin for such wide tires and a stock motor. I don't do burnouts but I do lanch hard on occasion and drive hard on windy roads on occasion too. But that isn't the main cause here. They are wearing strangely.
The tires were almost knew 4 months ago. In 4 months they have developed bad wear on both inside and outside of the tire. Outsides are worse. Very little to no wear in the middle of the tire.
Any ideas??
Old Jun 10, 2007 | 05:24 PM
irish44j's Avatar
retired moderator
have you had a recent alignment?
are your struts (shocks) in good shape?
how much are you lowered (if at all)?
what tire pressures are you running?
Proxes4 need to run higher pressures than stock...I run 36/35 on mine for even wear.
Old Jun 10, 2007 | 06:01 PM
goon9's Avatar
Sounds like sereously low tire pressure.
Old Jun 10, 2007 | 07:59 PM
EnervinE's Avatar
i has college
I've got the same problem with my Falken Ziex's (235/40-18) and my tire pressure is 46 psi.
I don't think tire pressure is the problem though, as my back tires are wearing normally.
Old Jun 10, 2007 | 08:26 PM
irish44j's Avatar
retired moderator
umm....your tire pressures are WAAAAYYY to high. WTF are you thinking?
Old Jun 10, 2007 | 11:36 PM
paemt6220's Avatar
No
Yes, new H&Rs with wheels and tires
yes, unknown I didn't install the H&Rs so i am not sure of the drop. Maybe 1" to 1.5".
35/34
I thought it seemed like low pressure. Check pressure several times a week to make sure it's ok. I did consider raising it.
I am going to have to check alignment(stupid of me not to have done so already). I am wondering if maybe I have exessive toe in since the worst is on the outside of the tires?
Old Jun 11, 2007 | 12:35 AM
SPiG's Avatar
SomePsychoGuy
H&R doesn't make a strut. Are you on stock struts?
Old Jun 11, 2007 | 02:49 AM
paemt6220's Avatar
Thanks for noticing my mistake!
KYB AGX Shocks
Old Jun 18, 2007 | 11:25 AM
EnervinE's Avatar
i has college
Actually, max tire psi for ziex ze512s are 50 psi.
Old Jun 18, 2007 | 01:08 PM
Digitized's Avatar
Should always stick to the recommended PSi of you vehicle and not of the tire..
Starrider
Sep 17, 2015 07:26 AM
homeyclaus
Sep 3, 2015 06:15 PM
mls277
Aug 11, 2015 07:18 PM
