Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
View Poll Results: Have you gotten the "woot-woot" (brake-related) when turning
I have the aluminum z23 calipers, and I HAVE gotten the sound
53.85%
I have the alumiunum z32 calipers and I HAVE NOT gotten it.
30.77%
I have the iron z32 calipers and I HAVE gotten the sound
7.69%
I have the iron z32 calipers and I HAVE NOT gotten the sound
7.69%
Voters: 13. You may not vote on this poll
Have a z32 front brake upgrade, step in.
Old Aug 28, 2007 | 08:38 AM
  #41
maximabebe's Avatar
Upon my Z32 30mm/13" Cobra install, I had a similar problem as far as the noise goes. I rebuilt my calipers myself using Nissan parts, without splitting the body halves.
On occasion, the noise I was hearing was:
1) consistent with vehicle speed/tire rotation
2) more like the pad dragging on the rotor's face
3) almost like the pad wasn't sticking to the piston upon return
4) happening (and more noticeable) upon slow speed turns (including reverse)
5) similar to bad wheel bearing noise characteristics
Old Oct 9, 2007 | 08:13 AM
  #42
maximabebe's Avatar
Originally Posted by soundmike
I meant the smaller "O" rings when you separate the piece. Apparently, splitting open the calipers tend to have issues if the rings aren't set right, or if they're not replaced.
From the how-to
I truly don't believe that these calipers were ever meant to be split. Even the new seal rebuild kits do not include the smaller o-ring for the caliper's internal.
Old Nov 2, 2011 | 07:35 AM
  #43
Kuhn_man's Avatar
XD i get this noise on my stock 4th gen brakes because the spring that holds the pad away from the rotor wasnt strong enough after years of use...
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
egali045
Aug 16, 2015 01:19 PM
kirkhilles
Aug 8, 2015 10:53 AM
