Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
350z 2 piston front brake upgrade!!!
Old Sep 7, 2007 | 05:46 PM
redls1's Avatar
MAXIN' ON
Ok I did the 350z rear caliper/SS line and cross drilled/slotted change to my 2007 maxima. I got my 2006 cross drilled/slotted rotors today and went to size them up with the 2006 2 piston calipers. Well the *******s only sent half the caliper. I dont have the bolts (no biggie) but also dont have the floating part of the caliper. It should be obvious that I cant use the other half of my original caliper right? If he doesnt have the other half should I get my money back or try and get the rest of the parts? Appreciate the help and yes I miss my Z. They arent open till monday but please somebody inform me.
Old Sep 8, 2007 | 05:23 AM
L.M.L.
I really could not understand what you are trying to do Your car is a 2007... what's 2006 part - Z calipers? If that's the case, could you enlighten me why you want to use them? It still uses 12.6" 20.5 lb rotors and cast-iron calipers. Just because it's a 2 piston design?
Some pictures would help too.
Old Sep 8, 2007 | 07:08 AM
redls1's Avatar
MAXIN' ON
All your points are valid but was told it was kinda like a brake upgrade. I wanted cross dried/slotted rotors and SS LINES anyhow so why not get 2 piston calipers instead of one? Wont it help?
Old Sep 10, 2007 | 02:08 AM
redls1's Avatar
MAXIN' ON
So is this not worth doing? Should I just pit my rotors asn SS lines on and call it a day?
Old Sep 13, 2007 | 04:56 PM
irish44j's Avatar
retired moderator
wait, so you upgraded the rear calipers but not the fronts?
Old Sep 13, 2007 | 07:20 PM
redls1's Avatar
MAXIN' ON
No I was going to do the front to the 2006 350z 2 piston calipers with SS line but the ******* compnay only sent half the rotors. So now Im broke and have to wait and get my money back to get new calipers and put everything on th fronts so Ill have both done.
Old Sep 14, 2007 | 06:59 AM
LA02MAX's Avatar
calipers should include the torque member. Call the company and tell them you want a refund or the entire part.
Old Sep 17, 2007 | 09:48 PM
Shogunsc4's Avatar
keep us updated on the upgrade...I have been thinking about doing a BBK with either a z32 caliper, q45 caliper, A34 caliper or maybe the Z's. How much did u pay for the Z's calipers?
Old Sep 18, 2007 | 04:38 AM
redls1's Avatar
MAXIN' ON
Ive got another place that wants $200 plus shipping. I already have my rotors and SS lines on. Just waiting on a refund from the other company as Im broke at the moment.
Matt93SE
May 24, 2019 02:58 PM
homeyclaus
Sep 3, 2015 06:15 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
