Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Rotors gone wrong!
Old Oct 9, 2007 | 07:04 PM
redls1's Avatar
MAXIN' ON
Post Rotors gone wrong!
I installed front cross drilled/ slotted rotors on my 07 max. On the right side when I hit a bump it doesnt sound right. It sounds like a thud or something is loose. I checked the caliper bolts and ofcourse all lugnuts are tight. Any suggestions?
Old Oct 9, 2007 | 07:33 PM
irish44j's Avatar
retired moderator
get used to noise if you want ricer drilled/slotted....
if you want advice on noise, you need to be more specific about what it sounds like. "It doesn't sound right" doesn't help us help you.
Old Oct 9, 2007 | 08:06 PM
redls1's Avatar
MAXIN' ON
Every time I hit a bump it goes thud but is louder than normal or different than anything Ive heard before. I had these types of rotors on 3 different cars and have never heard or had this noise before.
Old Oct 10, 2007 | 11:46 AM
Mr.Duck's Avatar
sounds like you have a blown strut to me....
Old Oct 10, 2007 | 11:56 AM
redls1's Avatar
MAXIN' ON
Thats what someone else said but I only 10k and am very carefull when driving as I have low profile tires and dont want to screw my rims. Could be a fluk I guess. Will take it into the dealer on friday.
Old Oct 10, 2007 | 01:45 PM
ShiftVQ35
^^^ thats nothing new. What do you expect it is nissan quality. If you are covered by warranty let them take care of it.
Old Oct 12, 2007 | 11:38 AM
Matt93SE's Avatar
STFU n00b!
if you've got suspension noises, check your brake install to make sure everything's tight, then take it to the dealer and watch them try to void your warranty because you touched the brakes.
Old Oct 21, 2007 | 07:17 PM
redls1's Avatar
MAXIN' ON
Actually my dealer is cool with my mods and said if it does directly effect whats broke he will fix it. He even re secured my front SS lines for me. They replaced the strut but said there is still a small noise they couldnt figure out. They will look at when I bring it in next for some other things. They actually notice that one of my rear cross drilled/slotted rotors had a crack and told me. I have a new set on the way.
Old Oct 31, 2007 | 11:51 AM
redlobster's Avatar
mine sounded similar and so did a friend with an 06 maxima
Old Oct 31, 2007 | 01:34 PM
redls1's Avatar
MAXIN' ON
After they replaced the strut I still had small noise. I went back and found that the bottom strut bolts were still loose as well as a couple of others. No more noise but the dealer should have found it.
Old Oct 31, 2007 | 03:45 PM
irish44j's Avatar
retired moderator
Happy you resolved the problem. Thread locking...
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
Socalstillen
Sep 26, 2015 12:01 PM
