Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
help with 300zx bbk on 4th gen pedal falls to the floor
Old Dec 3, 2007 | 03:48 PM
Big D's Avatar
hey wasup guys need some help i installed the 13" cobra and 300zx calipers put the stainless steel lines also after all thats i started bleeding the brake line after i finished the pedal feels like **** and falls to the floor so i bleed all the lines from front to back and it still feels the same
Old Dec 3, 2007 | 05:25 PM
00SEMAX19's Avatar
First thing to check is if the bleeder screw is on top of the caliper. If not then they are on the wrong corner of the car.
Old Dec 3, 2007 | 05:52 PM
MrDicks95SE's Avatar
Offset Is Everything.
I believe youre supposed to start with the caliper furthest away from the resevoir (passenger side Rear) and work your way up front to the driverside front. that's probably why it's so spongy and terrible.
Old Dec 3, 2007 | 10:20 PM
MaxBoost925's Avatar
Drug Money
+1.
You bleed:
RR
RL
FR
FL
Old Dec 4, 2007 | 05:36 PM
Big D's Avatar
ok will try to bleeding it for the far rear to the front and see how it feels i want to now how does the conversation compare to the stock
Old Dec 4, 2007 | 06:44 PM
Matt93SE's Avatar
STFU n00b!
1. make sure you're not ghettoing out and using banjo bolt brake lines.
2. check for leaks on all fittings you touched during the conversion.
3. look for brake fluid leaking form the caliper piston seals, body, and bleeder screw.
4. bleed again (any order you want- doesn't make that much difference) making sure you keep the master cylinder full and bleed ALL the air from the system.
if you have ABS, check the manual to make sure you're doing it right. I forget if the engine has to be on/off/ign on or whatever to bleed a system with ABS. make sure you're doing that, as it's critical with an ABS car.
Old Dec 4, 2007 | 07:45 PM
redls1's Avatar
MAXIN' ON
Originally Posted by MaxBoost925
+1.
You bleed:
RR
RL
FR
FL
Thats how I bleed my car but read somewhere it was
rr
lf
lr
rf
Did I read it wrong? Also read is car to be off.
Old Dec 4, 2007 | 11:21 PM
Drug Money
rr
lf
lr
rf
You want the bleed furthest from the master cylinder to the closest last.
RR is correct
LF is the closest unfortunately. So that's the wrong order.
Old Dec 5, 2007 | 06:21 AM
redls1's Avatar
MAXIN' ON
Cool atleast I did it the right way but I guess read it wrong.
Old Dec 7, 2007 | 04:11 PM
Big D's Avatar
i bleed the brakes over again from rr/lr/rf/lf and my pedal is still spongy what could be the problem the master
Old Dec 7, 2007 | 05:08 PM
MorpheusZero's Avatar
You need to read Matt's post. He knows his ****:
Old Dec 7, 2007 | 05:58 PM
irish44j's Avatar
retired moderator
If you just change the calipers, you don't have to bleed the entire car (assuming you didin't let the M/C fluid level drop below the minimum...
In any case, you definitely need to bleed it more. Also make sure to pump the pedal a few times with the car off to bleed air out of the ABS system (also pull ABS fuse when you do this).
MAXSE5SPD
Sep 17, 2022 04:00 AM
Matt93SE
May 24, 2019 02:58 PM
maxfever1987
Nov 19, 2016 08:01 PM
dinososexy2.6
Aug 31, 2015 05:37 AM
MikesChevelle
Aug 10, 2015 10:53 AM
