Fender braces who wants some?
They do well, there's supposed to be a bit of flex between the engine bay and the firewall/cabin, so they seem to do something to help reduce that chassis flex that occurs, little as it may be. The results are actually noticeable.
Thanks for the info anyway.
Sean has my 4th Gen in the shop right now working on a prototype. Hopefully we will have photos to post up later tonight or tomorrow. We will be running a group buy for these and we are kicking around a reduced price if you buy both chassis bracing and the fender bracing all at once. Not sure about prices yet, but we want them to be afordable. They will be a bolt on application. You will need to remove the fender of course to install.
Dan TMS
Dan TMS
Any twisting of the front end relative to the firewall, like a triangulated FSTB only better in some ways.
Alright the moment you have been waiting for some pictures of what I came up with. I didn't go crazy with putting the brace as far forward towards the bumper as possible. I do have a reason for doing so, my thought was the most energy transfered from the strut housing occurs at and behind the strut housing towards the rest of the chassis not towards the bumper so heres some pics.
Enjoy!
We will be posting a group deal later on tonight,
-Sean
Enjoy!
-Sean
I like the one butt ended connection but IMHO, the two others aren't joined as well as they could have been. Angle cut the ends and butt weld those two would be a "stronger" way to do it. AGain IMHO
Jeff the produced piece has gussets and is flush welded.
To take off fenders its mostly just bolts. I made sure not to use all the door mounting holes, as to not have anyones doors fall off, or need to be realigned for that matter.
It takes me less than 45 minutes to take off both fenders. There are two bolts hiden by the door itself, three nuts that mount the fender to the bumper, two bolts on the headlight, one screw on the turn signal, three bolts I believe on the fender under the hood. And they come off.
If you haven't been in an accident or have your fenders shimmed they should pretty much bolt back into place with just matching up the wear marks in the paint with the bolt head.
-Sean
TMS
-Sean
TMS
I see that now. But it seems like two of the square tubes are welded right on the edge of the gusset. Why not extend the top of the angle tube so you can weld it onto the middle portion. The bottom one, I would hope the gusset extends all the way to the end of the tube so it can be welded on both sides.
Any pics of the backside of this piece?
Enjoy!
http://i41.photobucket.com/albums/e2...erbrace003.jpg
http://i41.photobucket.com/albums/e2...erbrace002.jpg
http://i41.photobucket.com/albums/e2...erbrace001.jpg
-Sean
Enjoy!
-Sean
My quick thoughts- take them for what you will.
1. use larger tubing. 3/4" square tubing just isn't enough. use 1"
2. welding onto a piece of flat bar that long is going to turn the stiffness to crap. that long section of flat bar will buckle and bend. needs to be shorter and wider. have customer drill holes into fender and bolt through if they have to. I suggest just using longer bolts and extending the tubing to the end instead of welding to flat bar.
3. lengthening it toward the bumper more will result in a longer torque arm and more strength overall. miter the end of the angle bar to match the upper bar and you'll be able to weld it all the way around for more strength.
....... Deep thoughts from a drunk guy.
Sean and Dan,
Will any revisions be made before the design is finalized? Any thoughts/comments with regards to what Jeff and Matt said? I'm sure we would all like to hear your point of view.
Very nice! I know this is OT, but do you have any pics or a thread showing this? Feel free to PM me as to not ***** up this thread. Thanks.
I am working on addressing some minor design details. However I cant really use larger tubing as there just isn't ample clearance for the fender. As well flat stock is very strong with energy coming from one way, and very flimsy from the other. I tack this into serious accord, and the flat on the front is 1/4" thick so I dont see any detriment in using such material.
-Sean
-Sean
Still waiting for driving impressions on the test car. Haven't seen any activity in the group deal thread. If 1" square tubing really won't fit I'd at least like to see the final version with angle cuts and butt welds all around.
Thanks again for taking the initiative to make these! We're a tough crowd but I think you'll sell a lot of bars with those modifications.
Dan Truax PMed me recently and said "Just to let you know we are continuing to work on the fender braces. We want to make these strong as we can but also fit with ease. It is easy to fabricate a set for my car but when you are thinking of making hundreds of them, best to go a bit slow and make sure you have all your bases covered."
So it may be a while. I hope they'll be ready by spring.
Here's a very nice looking brace for 350Z and 240SX for inspiration.
http://www.mynismo.com/products/?id=6847#
These I would buy. The others pictured...I would just make myself. If I am going to pay mucho dinero, I want it to look as well as it performs.
Engineer it well, I don't care what it looks like save for weld quality and I will rip off any decals that are put on it
Because if I am spending my hard earned cash I want them to look finished and professional. If it looks like someone welded them up in their garage I am going to feel ripped off and would rather do that type of work myself. My rule of thumb is if it looks cheap it probably is.
Who the hell is going to look inside a fender to see a chassis brace? So you would spend more on a brace that looks better than a brace that is cheaper but doesn't look as nice but does the same thing? Cause what you are saying is very stupid.
