Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
LTB hits LCAs...notch LCAs?
Old Dec 21, 2007 | 10:48 AM
95maxrider's Avatar
Lightly modded
I took my car to a new, reliable mechanic and he noticed Matt's stage 2 LTB is pretty much resting on the LCAs (IIRC), and there is evidence that they bang against each other quite often. He mentioned I could notch the LCAs to get some space back, but I'm thinking there has to be another way to correct this problem. I haven't heard of other people with this problem, so I'm wondering if the LTB was somehow installed incorrectly. Maybe it could be fixed by adding a few more spacers?
Anyways, I don't want to spend $200 to notch the LCAs, but I will if I have to. Do you guys have any ideas about how to resolve the issue? I wish I had pics, but I forgot the bring my camera.
Old Dec 21, 2007 | 10:55 AM
secondtonone317's Avatar
nycnissans
LCA = lower control arm?
Old Dec 21, 2007 | 07:35 PM
irish44j's Avatar
retired moderator
pics.....I don't understand how they could be hitting the LCAs....
Old Dec 22, 2007 | 09:01 AM
Matt93SE's Avatar
STFU n00b!
pics please.
Old Dec 24, 2007 | 10:25 AM
MrDicks95SE's Avatar
Offset Is Everything.
i dont understand how it could be hitting the LCA.
Old Dec 24, 2007 | 11:12 AM
MorpheusZero's Avatar
What everyone else has said. Your mechanic might be FOS.
Old Dec 24, 2007 | 11:31 AM
internetautomar's Avatar
mod or sell?
Notching the control arm????? no way that should ever be done.
maybe the original installer installed it wrong
Old Jan 8, 2008 | 06:31 PM
95maxrider's Avatar
Lightly modded
OK, I got the car back up a lift and took some pics. Matt brought up a good idea in a PM: I ran over a deer going 70 mph last year, and there's a good chance the LTB was bent. I don't remember what it looked like new, but here's what it looks like now:
From the rust it looks like the two have hit each other many times. Is this normal?
This can't be good:
The next pic was supposed to show the curvature of the LTB, but it didn't turn out very well. Is it supposed to be completely straight or is there a slight bend in it?
Old Jan 8, 2008 | 06:34 PM
95maxrider's Avatar
Lightly modded
And here are some pics of the TBs for the hell of it
And this bolt isn't looking too happy:
Thoughts?
Old Jan 8, 2008 | 07:23 PM
Matt93SE's Avatar
STFU n00b!
The rubbing isn't the control arm itself. that's the bracket that holds the rear bushing in place. why it's rubbing I don't really know. I'd check the tightness of the bolts holding that bracket in place.
no, the front bar is not supposed to be bent like that. you whacked it good. that's probably enough to have lifted the car off the ground.
as long as your alignment is still in spec, I woulnd't worry about the bends tho..
Old Jan 8, 2008 | 07:58 PM
95maxrider's Avatar
Lightly modded
What about the clearance under the crossmember?
Old Jan 9, 2008 | 06:11 AM
Matt93SE's Avatar
STFU n00b!
Wouldn't worry about it unless it's causing problems. just rubbing on it won't do anything but mar the paint.
D Mason
Jun 21, 2016 04:43 AM
captchaos
Mar 15, 2016 12:18 PM
doctorpullit
Dec 12, 2015 09:39 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
