Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Rear passenger-side illumina --> weird noise
Old Jan 4, 2008 | 09:54 PM
Armon's Avatar
Just installed progress springs and illuminas all around. I have them set to 3f/4r, and had a loaded down trunk for my trip. I'm hearing a strange sound when I go over a "dip" that causes the rear end to compress. The sound is hard to describe, but it sounds like metal scraping metal. Almost a squeaking sound. Only happens when the shocks compress, and only one of them is making noise. It even happened once when I went over a speed bump. What are the culprits? Should I turn up the rear stiffness to prevent it?
Old Jan 5, 2008 | 03:44 PM
Fr33way™'s Avatar
Wild for Width
What's the torque like on the top hat nut? Do you have the isolators between the upper mount and the body? What were your bushings like?
Lot's of questions but barring strut defect that will route to your problem. Check the free/cheapest items first.
Old Jan 5, 2008 | 05:21 PM
MrDicks95SE's Avatar
Offset Is Everything.
+1 on the nut and isolator. re-install it and see if the problem persists.
Old Jan 5, 2008 | 05:30 PM
Armon's Avatar
Based on the sound, I'm thinking maybe I over-torqued the top hat nut. I'll check it out and report back. Thanks.
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
doctorpullit
Sep 10, 2015 06:33 PM
Justin Kroll
Sep 2, 2015 11:06 AM
