Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
5th Gen Wheel Stud Knurl Size?
Old Feb 19, 2008 | 10:06 AM
Prophecy99's Avatar
I am ordering Extended Studs for the installtion of 20mm H&R rear spacers and
I thought I was set on what to get but am getting quite confused on what the Knurl Size is for a 5th Gen?
I know I need 12x1.25 studs (and for w/e length in my case 50mm shank) but what about for the knurl size?
For example these sites have essentailly the same 12x1.25 studs but various knurl sizes
12x1.25_50mm shank(20mm spacers)___13mm Knurl
example 1
and
12x1.25_50mm shank(20mm spacers)___14mm Knurl
example 2
last but not least
12x1.25_50mm shank(20mm spacers)___12.75mm Knurl
example 3
thanks
Old Feb 19, 2008 | 02:08 PM
Matt93SE's Avatar
STFU n00b!
According to Courtesy's site, 4/5 gens use the 14.3mm knurl.
My VE actually uses both, depending on the production dates of the hubs. fronts are 14.3, factory original rear hubs used 13mm. replacement OE hubs uses 14.3. (and I only replaced one rear hub, so I have 3 hubs at 14.3 and 1 hub at 13... grrrr)
anyway, here's the elimination process:
http://www.courtesyparts.com/nismo/bolts/index.html
click on any of the parts in the box that says "fits anything with solid rear axle" (That's 4/5gen Maximas)
http://www.courtesyparts.com/Merchan...de=40222-00005
doesn't specifically say Maxima on there, but it shows the others that do and they match up. I know for a fact my S14 uses 14.3mm in the front and it's on the list. Then if you look at the drawing, it shows the 14.3mm knurl on there.
Old Feb 20, 2008 | 09:29 AM
Prophecy99's Avatar
thanks matt you da man.....i am tryin to ordering now.....but non of these sites have 14.3mm specifically available? Only 14mm . Is that acceptable? i just want to make sure...
Old Feb 21, 2008 | 06:35 AM
Prophecy99's Avatar
For those still wondering. An acceptable size to order is 14mm. Even though technically 14.3mm is the actual size. Case Closed . Thanks again.
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
maximaham
Aug 20, 2015 10:23 AM
Xi MaX SC
1/4 and 1/8 Mile Racing
Aug 7, 2015 08:47 AM
