Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
should I force the camber to be the same?
Old Mar 25, 2008 | 09:26 PM
97SEdriver's Avatar
this place is dead
firestone lifetime alignments are good.......but.....
when I went this last time, here's what I got
So, the question is....do I go out and get some camber bolts or something to at least force them to match?
My left front is starting to cord on the inside since the wife curbed it and I ignored it for a while....but I know they do the camber when it's still in the air.
Should I care?
if you can't make out the pics, the camber is -1.4 L and -0.7 R
Old Mar 25, 2008 | 09:53 PM
MorpheusZero's Avatar
Yes.
Camber is important, your car can develop a pull if it's too uneven.
The alignment dude should at least be able to get them within a few tenths of each other.
Plus you can run a little moar for mad tyte handlings, I try to keep it around -2 degrees. I get camber wear but it is not too bad if you drive like a madman.
Also, they don't measure the camber when it's in the air... that would be retarded. I'm not completely sure what you mean by that.
Old Mar 26, 2008 | 10:28 AM
MrDicks95SE's Avatar
Offset Is Everything.
Originally Posted by MorpheusZero
Yes.
mad tyte handlings eh? perhaps i should invest in camber plates to get this -2* mad tyte-ness. perhaps with the low offset 19s i may need them and bend the rear beam
97SEdriver: take it back and have them re-adjust it to the specs you need. btw alignments are done with the car sitting on all four wheels on the ground with suspension under normal load. gotta be on crack for the suspension to be hanging and do an alignment like that...
Old Mar 26, 2008 | 10:57 AM
97SEdriver's Avatar
this place is dead
In the air is the wrong way to say that.....I meant on the alignment stand...hence...not on the ground....
Old Mar 26, 2008 | 12:20 PM
G4nismo's Avatar
Should I care?
wow, i would take your car back and have them realign that. your camber is pretty off. should be within those nominal brackets close to each other as possible.
heres the factory specs:
FRONT WHEEL ALIGNMENT
Camber, in degrees.
-1.00 Minimum
-0.25 Nominal
+0.50 Maximum
+0.75 Maximum left and right difference
Caster, in degrees
+2.00 Minimum
+2.75 Nominal
+3.50 Maximum
Kingpin inclination, in degrees
+13.50 Minimum
+14.25 Nominal
+15.00 Maximum
Total toe-in distance, in millimeters
+1 Minimum
+2 Nominal
+3 Maximum
Total toe-in angle (left plus right), in degrees
+0.09 Minimum
+0.18 Nominal
+0.27 Maximum
REAR WHEEL ALIGNMENT
Camber, in degrees
-1.75 Minimum
-1.00 Nominal
-0.25 Maximum
-3 Minimum
+1 Nominal
+5 Maximum
-0.27 Minimum
+0.09 Nominal
+0.43 Maximum
camber is the most important. also if your pulling slightly in either direction, its b/c of the camber. is your suspension stock or aftermarket? if aftermarket and have elongated struts holes, just tell the mechanic to mess around w/ that for more camber adjustment.
Old Mar 26, 2008 | 12:24 PM
G4nismo's Avatar
i actually need to get another alignment really really bad. outer front tires are worn like hell and the car pulls to the left. i am running a lot of neg camber, for auto-x and that "mad tyte handlings"
how much is it for the lifetime aligntment?
Old Mar 26, 2008 | 02:11 PM
97SEdriver's Avatar
this place is dead
I think when I did it...it was around $150, but since then I've done it 4-5 times at least.....
Old Mar 26, 2008 | 03:37 PM
97SEdriver's Avatar
this place is dead
I guess I have mad-tyte handling when I'm turning left anyway.....ftw(?)
Old Mar 26, 2008 | 05:24 PM
G4nismo's Avatar
$150 is not bad at all considering 1 time alignments usually cost around $50 -60 ish. if you adjust and messing w/ your suspension a lot, mine as well get the lifetime.
matts95max
Apr 23, 2025 10:44 AM
James92SE
142
Jan 2, 2024 09:23 AM
A32goldylocks
Sep 2, 2015 06:39 AM
FlaMark
25
Aug 28, 2015 10:15 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
