Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
another way to bleed rear brakes?
Old Mar 30, 2008 | 07:37 PM
black_maxed95's Avatar
does anyone know if there is anyway to bleed the brakes without using the bleeder bolt? I replaced my RL caliper since my old one was siezed. Well the used caliper i got had a very rusted bleeder bolt...tried to be very careful in loosening it but I still ended up in breaking the top off. So now im screwed with mushy brakes until I buy another caliper unless someone knows of another way...
Old Mar 30, 2008 | 08:04 PM
jdmkuruma's Avatar
thats the only way i know how to bleed brakes.
Old Mar 30, 2008 | 08:05 PM
ya I think im gonna have to buy another one...
Old Mar 30, 2008 | 08:23 PM
Matt93SE's Avatar
STFU n00b!
go to the parts store and buy a remanufactured caliper. they're not that expensive....
Old Apr 1, 2008 | 10:01 AM
mikekantor's Avatar
Have you tried applying a penetrating spray, drilling, and extracting?
Old Apr 1, 2008 | 01:11 PM
i1k's Avatar
i1k
i had to use a screw/bolt extractor (bought at Sears) to remove the broken bleeder bolts from both front brakes of my '69 cougar.
it's like a drill bit with reverse tapered cutting screw threads that are designed to screw counter-clockwise into the screw/bolt (usually after a pilot hole has first been drilled which I had to carefully do). you dont want to drill the pilot hole so big that using the screw/bolt extractor will disintegrate the bleeder bolt.
also, its tapered so that turning the extractor threads dig into the damaged screw/bolt deeper and tighter and also turns the damaged screw counter-clockwise which loosens and removes the damaged screw/bolt.
AcuraLegend
Oct 17, 2016 08:47 PM
Huttig2009
Sep 25, 2015 03:31 PM
AcuraLegend
Sep 22, 2015 04:22 PM
homeyclaus
Sep 3, 2015 06:15 PM
A32goldylocks
Sep 2, 2015 06:39 AM
