Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Rear link swap out.
Old Apr 12, 2008 | 07:11 PM
goon9's Avatar
Rear link swap out.
Here's what I'm trying out for my rear suspension.
The 4 parallel links are are steel with grease fittings for the chromoly hiem joints.
The 2 lateral are steel, no grease fittings, teflon hiem joints.
To compensate for being lowered I raised the inner mounting points. This gave the link angle a more positive angle till full compression. I also replaced the tiny bolts with 5/8's bolts and 3/4 bolts all grade 8(Standard bolts because I didn't want to use bushings with the hiem joints). I know it's over kill but it's a little more piece of mind for me. Also before being lowered on stock links, they sat at a negative angle. So when under compression the wheel would tuck inside the well, leaving me with 5mm a room between the already stretched tire and rolled fender. So after I swapped over, the links the wheel actaully pushes out and no longer inside of the wheel well. To remedy I flared the fenders a tad.
Old Apr 12, 2008 | 07:31 PM
MorpheusZero's Avatar
Nice man, let's see a picture of the whole car.
Old Apr 13, 2008 | 02:21 AM
jonmandude's Avatar
Isn't that the same as Matt's (Blehmco) stuff?
Old Apr 13, 2008 | 06:24 AM
goon9's Avatar
Not part for part. The lateral rod is similar but i think a little bit thicker.
Old Apr 15, 2008 | 11:51 AM
4signs's Avatar
nice job man
how wide are those wheels?
Old Apr 15, 2008 | 01:54 PM
goon9's Avatar
Originally Posted by 4signs
nice job man
9 wide, the tires are around 245 stretched on.
Old Apr 15, 2008 | 03:43 PM
Armon's Avatar
does this mean no RSB?
Old Apr 15, 2008 | 05:27 PM
goon9's Avatar
No I'm putting the stock one back in till I can afford a better one.
Old Apr 15, 2008 | 09:49 PM
MrDicks95SE's Avatar
Offset Is Everything.
thats some nasty negative camber wear on those tires. rear assembly is really clean! but your under carriage could use some coating. massive rusting ftl.
Old Apr 16, 2008 | 07:46 AM
BLACKonBLACK98's Avatar
Former Vendor
i want irs.
Old Apr 16, 2008 | 08:07 AM
Armon's Avatar
how/where will you attach it?
Old Apr 16, 2008 | 09:56 AM
jonmandude's Avatar
I just noticed that you cut your trunk well out.
Old Apr 16, 2008 | 01:59 PM
goon9's Avatar
yup, i Just redid it and will seem seal and prime this weekend.
Old Apr 16, 2008 | 02:15 PM
goon9's Avatar
Well I don't have any pics... but it mounts in the stock location.
Old Apr 16, 2008 | 05:05 PM
Originally Posted by BLACKonBLACK98
i want irs.
me too.
Old Apr 16, 2008 | 08:56 PM
Originally Posted by Mr****s95SE
me too.
Yah, but you only want it so you can camber in the rears and run stupid offset.
Old Apr 17, 2008 | 07:43 PM
goon9's Avatar
Sounds like a good reason
I mainly did it for the strength vs. stock as well as bring back some of the handling.
Old Apr 20, 2008 | 11:24 PM
Let's see a few shots of the whole car?
Old Apr 21, 2008 | 03:52 PM
goon9's Avatar
I don't have any Real current pics seeing as how everything in the engine bay is being redone as well as and over haul on the rear trunk and fenders. But here's what it lookeded before i tore back into it.
Here's the bay right now. I had to stop on it to finish up the rear.
Front bumper is staying the same, the side skirts will be modified to match the bottom body line better.
I can snap some pics of it on jack stands.... But i think you get the idea.
Old Apr 25, 2008 | 08:17 AM
Matt93SE's Avatar
STFU n00b!
looks good to me. how's the camber curves look for the rear links in that location? Moving the mounting points that much makes me worried about camber gain/loss during cornering.. so what suspension are you running on it now? springs/shocks/mounts?
Old Apr 25, 2008 | 01:12 PM
goon9's Avatar
I've looked at other ppl's set-ups and noticed they had much longer links and thought it was worth trying. I'm going to probubly have it set around -.1 for the rear and i think it should be ok, I'll probubly be adjusting it for a little while to what feels right. It's only going to be used on the street but I wanna milk as much as i can out it.
To get and idea of the travel and curve I'll probubly make a video when I get it all tightened up.
For now kyb's and intrax. I'm shooting for konis with modified boots in the next upgrade as well as better sway bars.
Old Apr 25, 2008 | 10:10 PM
dont hate cuz only the cool people are doing it
Old Apr 26, 2008 | 09:39 PM
Armon's Avatar
so, who wants to make this setup for 5th gens?
Old Apr 27, 2008 | 07:09 AM
Matt93SE's Avatar
STFU n00b!
It'll cost about $10,000....
Old May 2, 2008 | 03:26 PM
Prophecy99's Avatar
thats a lot of work goon.... props....
Old May 3, 2008 | 08:51 PM
goon9's Avatar
Old May 4, 2008 | 01:59 AM
Why would I hate for an oxymoronic reason?
Slamrod
Apr 10, 2016 05:24 PM
Huttig2009
Sep 25, 2015 03:31 PM
JoshG
21
Sep 4, 2015 09:04 PM
homeyclaus
Sep 3, 2015 06:15 PM
