Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
BBK fitment
Old Apr 15, 2008 | 01:56 PM
goon9's Avatar
BBK fitment
Does this look right?
Old Apr 15, 2008 | 02:03 PM
Jeff92se's Avatar
I'm needing a caw
Yup. it's only 1-2mm and I ran it this way for years. Eventually I broke off the pad lip that developed but no biggie. Never had any noise/squeal problems associated with it, not does it affect anything. Wait until you drive on it. ESPECIALLY if you have the Z31 rear upgrade. It's freakin' nice.
Old Apr 15, 2008 | 03:25 PM
goon9's Avatar
Oh good, I can't wait to drive it! It maky be a few months till it's road worthy...
Oh, I put on my wheel for clearance, the wheel fit fine. But i Spun the wheel and snapped off the chrome valve stem! Crappy... I need a flush kind of valve stem now.
Edit: z31 upgrade on too.
Old Apr 16, 2008 | 02:49 PM
GAMERA30's Avatar
From: Long Beach, CA is where i live. Queens NYC is always home.
YEAH... thats right. Mine does that too. I did a BBK w/ brembo z33 rotors and z32 calipers on my friends s13.it did that also. It`s because the arc of the rotor is wider then what the calipers were really made for.I had to use J30 calipers because the Z32 calipers dont clear my spokes on my rims Jeff is right.. wait till u do z31 rears ... i`m having fun w/ mine...lol
Old Apr 17, 2008 | 06:56 AM
t_ahan's Avatar
300zx bbk
does anyone know if BlehmCo's 300zx kit with the 04 rotors will clear the 03-04 Infiniti G35 17x7 (alloy), 6-spoke wheels on a 96 max?
Old Apr 17, 2008 | 08:36 AM
GAMERA30's Avatar
your best bet is to test fit Mr.T. I think it should. The 04 rotors are positioned more inward the the Cobra rotor.I thought my Z32 calipers would clear w/my rims but no dice. Thats Y i run J30.The RWD Nissan/Infiniti rims "should" clear Matts kit. The Z/G rims have more nigative offset.
Old Apr 17, 2008 | 08:41 AM
GAMERA30's Avatar
I think it should. RWD Nissan/Infiniti rims have more negative offset.
Old Apr 17, 2008 | 11:27 AM
Jeff92se's Avatar
I'm needing a caw
COUPE 17s = probably
SEDAN 17s = probably not
Yes, the they are different wheels. They LOOK very similar though.
Old Apr 17, 2008 | 12:07 PM
IHAVEA2KMAXIMA's Avatar
The offset made the spokes for the coupe to be more concaved... therefore they can house the BBK. I dont think you can fit the 300zx BBK with G sedans unless you get like 10-15mm spacers.
Old Apr 22, 2008 | 07:39 PM
irish44j's Avatar
retired moderator
agreed. The coupe 17s don't have much clearance (10mm maybe), and they are 30/33 offset and 8" wide while the sedan 17s are (IIRC) 40 offset and 7" wide....you would probably need a spacer.
Old Apr 23, 2008 | 11:10 AM
GAMERA30's Avatar
If using the sedan rin w/ 40mm orrset.. then probably NO. My rims have 40mm offset and I had to use Infiniti J30 calipers .. see pic
Old Apr 25, 2008 | 08:14 AM
Matt93SE's Avatar
STFU n00b!
Offset from a different rim doesn't matter at all though. It's all about the spok design of that particular rim.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
Quickgtp
Apr 13, 2017 03:30 PM
maxfever1987
Nov 19, 2016 08:01 PM
BkGreen97
Apr 2, 2016 05:47 AM
