Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Question about rear springs??
Old Apr 22, 2008 | 06:35 PM
WhiteMaxima9600's Avatar
Quick and easy question.... Do you need a spring compressor to put on the rear spring assembly? I know u do for the front of course but can u get the factory spring back on without it or not?
Thanks.
I have lowering springs on the back and im putting the factory 4x4 springs back on just so u get the idea.
Old Apr 22, 2008 | 07:33 PM
irish44j's Avatar
retired moderator
it will depend on the springs and how tall they are. Tein H-techs I did without the compressors. Eibachs I used compressors. Maxspeeds used compressors.
If you have compressors, just try and see yourself. You need them for the front anyhow.
Old Apr 22, 2008 | 11:15 PM
Well i did the front ones last week and I don't have the compressors anymore. I mean i can get some loaners from the part store but I was just wondering if it was possible to do without them.
Old Apr 23, 2008 | 03:42 PM
Did them today, u don't need a compressor for the rears just in case anyone wonders.
Old Apr 24, 2008 | 01:52 PM
bambino's Avatar
jus the front ones, of course.. question, was it a pain to remove the bolts and stuff? after you remove the wheels? I heard the fronts are easier than the back ones...
Old Apr 24, 2008 | 10:33 PM
Nah, bolts are easy, But be careful when you tighten the bottom bolt or u will strip out the little tab that hold the nut.. then u have to weld it like i did. But compared to the front the rears are pretty straight forward.
Old Apr 29, 2008 | 08:53 PM
Fr33way™'s Avatar
Wild for Width
Negatory. Back moves much quicker than the front, no spindles, axles, strut bearings, and the units are more compact and easier to maneuver.
vingodine
45
May 21, 2016 12:46 PM
incubusjohnny
Nov 3, 2015 05:18 PM
Huttig2009
Sep 25, 2015 03:31 PM
JoshG
21
Sep 4, 2015 09:04 PM
homeyclaus
Sep 3, 2015 06:15 PM
