Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Making a strut bar, need input.
Old May 19, 2008 | 04:12 PM
goon9's Avatar
The new intake is much taller than a stock manifold. So I need to make one. I'm trying to keep the weight down but more importantly restore the structural integrity. Here's the main bar and I'm thinking I need to add 2 more bars. Any thoughts?
The itty bitty bolts are temporary till i order some beefier ones. Also the bar looks close the manifold I know But... My mounts basically SOLID and will not move. I'm also going to add a lower tie bar to help.
Old May 19, 2008 | 06:40 PM
BLACKonBLACK98's Avatar
Former Vendor
man i have no idea what to tell you but that is some serious fab. im looking forward to see this one get finished up.
Old May 19, 2008 | 06:54 PM
G4nismo's Avatar
looks fine to me! good work, wish i had a welder
Old May 19, 2008 | 07:05 PM
irish44j's Avatar
retired moderator
is there some background to what's going on here? Are you missing part of the engine cradle as it appears?
Old May 19, 2008 | 08:03 PM
Kevlo911's Avatar
Kevlo for President
When the engine moves it will hit it if that is how the final fab up will be
Old May 19, 2008 | 09:12 PM
MrDicks95SE's Avatar
Offset Is Everything.
not alot of leeway for that bar and engine. id push it out just a tad bit more.
for the final design, try placing more support from the bar to center of firewall in a triangular shape. or from the towers themselves to the firewall. that should stiffen it up a bit.
something like this:
Old May 20, 2008 | 01:38 AM
jonmandude's Avatar
This is what I was going to suggest as well. Remember the mid-60's shelby Mustangs? They used a triangulated strut bar system.
Old May 20, 2008 | 05:20 AM
goon9's Avatar
Oh nice, I like the tri-bar. I REALLY doubt my motor will move more than 3/4 of an inch, because the mounts are solid. But I'll see about moving it out more.
It looks like alot is missing, Thats only because I removed some sheet metal.
In the event it would move under hard acceleration the top of the manifold would move away from the bar. And I would never drop the clutch in reverse so I'm good on the clearance.
Old May 24, 2008 | 01:21 AM
Originally Posted by goon9
... because the mounts are solid....
i do realize the engine moves in back motion under acceleration but i just dont rigid parts that are too close to the engine. even if you have solid mounts, it'd make me nervous lol.
matts95max
Apr 23, 2025 10:44 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
