Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Rotors
Old Nov 3, 2008 | 02:50 PM
speed racer's Avatar
Rotors
Sorry to post this. The search button doesn't seem to work. I'm trying to help out a friend. He is experiencing shaking when braking which automatically suggests his rotors are warped. I recently changed his pads two weeks ago front and rear. I didn't see any big signs of hot spots or I might have overlooked it. But my question is, what other way can you check or properly diagnose a bad rotor? Any tools or tricks?
Old Nov 3, 2008 | 03:22 PM
IHAVEA2KMAXIMA's Avatar
I thought you were suppose to lathe the rotor everytime you change the pads.
Old Nov 3, 2008 | 03:43 PM
No you don't have to. Only time to cut it is when you scorn the rotor but taking material off the rotor is actually not good. The rotor just becomes more susceptible to warping b/c there is less material. Think Thermal.
Old Nov 3, 2008 | 03:50 PM
Oh, my mechanic told me that. Sorry I wasn't helpful.
Old Nov 3, 2008 | 07:54 PM
Greeny's Avatar
¯\(°_o)/¯
Have the rotors cut, or replaced..
Old Nov 4, 2008 | 04:49 PM
Well I purchased a micrometer. Will be checking variable thickness.
Old Nov 4, 2008 | 06:29 PM
MorpheusZero's Avatar
Rotors typically don't warp. This is sort of a brake myth. 99+% of the vibrations that people experience upon braking are uneven deposits of pad material on the rotors. This is caused by stopping on hot brakes. You can try and perform some hard cold stops on abrasive pads, or you can sand, lathe or replace the rotors and the problem will go away (sanding is iffy, you've got to sand the hell out of it).
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Socalstillen
Sep 26, 2015 12:01 PM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
