Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
does the 26mm caliper same fitting as 30mm??
Old Jan 5, 2009 | 08:45 PM
mastere954's Avatar
do both the 26mm and the 30mm 300zx calipers have the same brake line fittings?
Old Jan 6, 2009 | 09:01 AM
Matt93SE's Avatar
STFU n00b!
Yes. Everything is identical except the opening width and the length of the slider pins and spring (because the opening is bigger).
Old Jan 6, 2009 | 09:18 AM
Jeff92se's Avatar
I'm needing a caw
26mm calipers will only work for the 300z rotors. If you want to use the big rotors, it won't work.
Old Jan 6, 2009 | 11:06 AM
mastere954's Avatar
^^^ yea i know thats the setup i have now but i just bought some 30mm and the rtp cobra rotors, already have the lines, and ill be buying the brackets off of you in about a week
Old Jan 6, 2009 | 11:12 AM
mastere954's Avatar
btw the ss lines i have now with the z32 conversion also work with my my stock maxima calipers!! i thought they were different fittings? i remember i installed the lines, connected the z32 calipers then my wheel wouldnt clear so i left the sslines hooked up and connected the stock maxima caliper back while i got spacers. and the calipers worked just fine!! so what exactly is the difference in the 300zx fitting?
Old Jan 6, 2009 | 03:30 PM
Matt93SE's Avatar
STFU n00b!
The Maxima caliper is designed for a banjo fitting. The Z caliper is designed for an inverted flare fitting.
Just because one *might* fit in the hole and work for a short while in place of the other, eventually it's going to have problems by coming loose or leaking.
Look inside that Maxima caliper. do you see the inverted flare mating surface for the Z line? I didn't think so. That mating surface is what technically seals the fitting, NOT the threaded portion.
Look on the Z caliper. do you see a flat, machined surface and ears on the outside of the caliper to attach the banjo bolt and copper crush washer? I didn't think so.
Given enough vibration, the banjo bolt will eventually twist against the Z caliper and leak. You're also damn lucky if you ever get it to seal since the copper crush washer sits against cast aluminum/iron on the Z caliper vs. a machined steel mating surface on the Maxima caliper.
the ONLY similarities in the fittings is that they use an M10x1.0mm thread on them.
Old Jan 6, 2009 | 08:09 PM
mastere954's Avatar
ok now i understand. very helpfull info matt93se. thank you
Old Jan 30, 2009 | 06:39 PM
96blkonblkse's Avatar
My friend with his S13, has the Z front calipers, and he has used his stock lines which are the same as the maxima. Hes been on the same calipers for over 4 years, tracked the car so hard hes boiled the fluid, warped, rotors, destroyed pads, and hes never had his line leak.
Im not saying thats the proper way, because it is dangerous, go out and buy some S13 to Z32 conversion lines. I got mine from PDM racing, they are the same for the maxima, smae lenght and everything.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
