Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Eibach/ Illuminas now my car is a drift car
Old Dec 5, 2008 | 12:46 AM
Reket's Avatar
Well its not really a drift car but the rear end comes out on me all day long. I have GoodYear GSD3 an adjustable RSB and eibach/ Illuminas with the front set to 3's and back set to 4's. I live in a place where the roads are complete Sh%* so I cant set to a firmer setting. Everytime I go through some turns I notice my rear ends slides out on me, any tuning tips you guys maybe I should set the rears to a softer setting or is the rear sway bar adjusted to aggressive, the brackets are currently set right past the brake line. Any tips greatly appreciated and thanks for your time.
Old Dec 5, 2008 | 08:37 AM
sciff5's Avatar
I almost find this hard to believe.. If theres anything a Maxima is not.. its tail happy, although I did find after installing the same setup I was able to rotate the rear end very slightly under very hard cornering, but deff nothing I would consider tail happy.
To address your issue. I dont know what RSB you have but very generally a very tight RSB will reduce your traction out back. Try loosening or taking off the RSB and see if that makes any difference.
Old Dec 5, 2008 | 08:38 AM
mtrai760's Avatar
'Trynna' is not a word
New tires?
Old Dec 5, 2008 | 12:57 PM
Reket's Avatar
Nope tires have been on the car for less then a year.
Old Dec 5, 2008 | 07:06 PM
Crusher103's Avatar
Id try disconnecting one side of the RSB and see if it still very tail happy, does it feel unstable at all while cornering?
Old Dec 5, 2008 | 10:52 PM
The Law's Avatar
I R The Law
I don't know what you're experiencing cause I've had that setup on my car for 3 years and I have never had such a problem.
Old Dec 6, 2008 | 07:07 AM
sciff5's Avatar
Plus I have proxes4 with about 55k on them so they are pretty well done and I still dont have that issue, nor should normal wear create an oversteer condition because if anything, these cars wear the front tires more than the rears which should make understeer more prominent.
Like I said before the only thing I can think of is the rear sway bar.. other than that I would try loosening the rear struts a click.. but if the rear sway bar doesnt fix it.. I dont know what to tell you.. Theres not a lot on these cars thats adjustable so we're not working with tons of variables like a race car.
Did you change anything else on the car before you started noticing this?
Or was it a pretty sudden and immediate change after the springs/struts install?
Old Dec 6, 2008 | 07:51 AM
mist max2000's Avatar
did you buy the springs new or used?.. who installed them? maybe you got screwed maybe you have stock/not eibach springs on the front and the back is wicked stiff with eibach springs? know what im sayin?.... only thing i can think of.. cuz like others have said not much is adjustable.....do u have an RSTB of FSTB on?
Old Dec 6, 2008 | 07:19 PM
MrDicks95SE's Avatar
Offset Is Everything.
sturt bars only aid in chassis bracing/stiffening.
Old Dec 6, 2008 | 07:40 PM
MorpheusZero's Avatar
Try firming up your front struts (or loosening up your rears) by two clicks, or try removing the RSB (or just unhooking one side).
With my rear struts on full firm and the fronts on 1/2 way (and a RSB) I can definitely feel the car's tossability... feels like it corners pretty neutrally, under neutral throttle there is very little understeer to the point where it feels I'm almost oversteering, but I've never had to countersteer yet unless I was trail braking.
Old Dec 24, 2008 | 06:01 PM
Dive n Drive's Avatar
You must have a pretty meaty RSB to create overstear on a front wheel drive car.
Old Dec 26, 2008 | 01:15 PM
hmm u ever fix this?,... maybe while installing u f'd up the brakes,.. and now u have a semi sticking capiler?,.. or maybe your e brake is causing it to stick.. that would help oversteer but still not like u say.. idk..if ur near snow i sure hope u dont drive in it like that lol
Old Dec 28, 2008 | 08:53 PM
gene_vq03's Avatar
Could be your battery
Old Dec 31, 2008 | 05:55 PM
irish44j's Avatar
retired moderator
your tires must be garbage. I ran Eibachs/Illuminas with a RSB for well over a year (before adding other things) and never lost the tail, even in heavy autocross maneuvers.
You sure you're actually losing the tail, because with the beam axle/"panhard bar" setup you might just be feeling the axle shift, which gives the feeling of the tail sliding but the tires aer actually gripping fine.
Stiffen up your front struts. I always ran fronts at 5 and rears at 3 or 4....stiffer in back creates more oversteer.
Old Jan 1, 2009 | 07:07 AM
ColdSHO's Avatar
even with my jic rears set on theyre firmest with 8k springs i dont get crazy oversteer. i think my cars rather neutral. the rear can be swung out but its not easy nor usually benefical to me. perhaps its just that ur not used to the new way the car feels. everytime i do suspension work i have to relearna bit how the car reacts to the road.
Old Jan 1, 2009 | 09:09 AM
Drockb418's Avatar
i only have that prob trashing the living blank out of it on the auto x... to the point were im tiring to do it for fun. or on a highway on ramp were it gets tight at the last min.
Old Jan 5, 2009 | 02:27 PM
rxm6's Avatar
Agreed. I can purposely lose the tail with DD tires on wet pavement, but I have never lost the tail before hitting understeer in performance situations (even with stickies on the front and DD's on the rear, ahh the poor college days )
Old Jan 7, 2009 | 01:01 PM
ThurzNite's Avatar
The guy answered his own question/concern. The roads suck...he's getting bump oversteer, not the oversteer most of us encounter on the track or auto-x. His rear is too stiff, as many have pointed out. So loosen up the rear... softer setting on the illuminas, remove the RSB, drop rear PSI a bit.
Dr J
Old Jan 11, 2009 | 04:00 PM
a33i30's Avatar
this happened to me yesterday and i have stock shocks/springs. i was REALLY giving it everything and it was on a mountain road over a crest. But I was supprised it actoully oversteered, wasn't expecting that.
Old Jan 11, 2009 | 05:48 PM
ThurzNite's Avatar
a33i30: describe the road conditions. Do you remember the 3rd gen chase through #2 hwy that ended in oversteer?
Old Jan 11, 2009 | 07:50 PM
Snypa's Avatar
damn @maxima rear end sliding out.
Old Jan 12, 2009 | 09:53 AM
rxm6's Avatar
Originally Posted by a33i30
...it was on a mountain road over a crest.
There is your answer. Weight transfer over crest means less weight on the back wheels, which in turn means less friction on the road from your tires, which means oversteer possibilities.
Old Jan 13, 2009 | 01:14 PM
Torgus's Avatar
if the maxima was fwd and not rwd we wouldn't have this problem.
Old Jan 14, 2009 | 08:22 PM
rxm6's Avatar
Old Jan 15, 2009 | 11:21 AM
Torgus's Avatar
heh
Old Feb 1, 2009 | 12:48 PM
a33i30's Avatar
clear roads, it was hot that day, the car basically started understeering then i tapped the brakes a little and the a$$ went out, i tried the same corner the other day and it didnt oversteer O_o. It was probably becouse i tapped the brake.
Old Feb 1, 2009 | 07:38 PM
essential1's Avatar
My axles cry for mercy...
It shouldnt be surprising that you oversteered then...
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
