Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Brembo rotor dimple's
Old Mar 22, 2009 | 10:14 AM
Quickywd01's Avatar
I recieved two front brembo blanks for my 4th gen and one has two dimples on the rotor while the other doesn't. Are both rotors supposed to have these dimples? Also one rotor has brembo stamped on it and the other doesn't. Should both have brembo stamped on them?
Old Mar 22, 2009 | 12:05 PM
Matt93SE's Avatar
STFU n00b!
One is Brembo. The other isn't.
Old Mar 22, 2009 | 12:50 PM
MadMaxSE-L's Avatar
Doggah Bite...
Yeah, those should definitely not be there...
Old Mar 22, 2009 | 12:55 PM
Old Mar 22, 2009 | 02:07 PM
Quickywd01's Avatar
I'm going to RMA the dimpled one. Autobarn sucks.
Old Mar 22, 2009 | 04:04 PM
Matt93SE's Avatar
STFU n00b!
The dimples are wear indicators. When they're worn smooth, the rotor is done.
Old Mar 22, 2009 | 06:55 PM
MadMaxSE-L's Avatar
Doggah Bite...
WTF - what ever happened to having the minimum thickness stamped on the outside of the rotor???
Old Mar 22, 2009 | 07:53 PM
MROTH's Avatar
ive got demples on my brembo rotors... i thought they were just wear indicators also....
Old Mar 22, 2009 | 09:13 PM
MadMaxSE-L's Avatar
Doggah Bite...
None of the 4 Brembos on my Max have them, but they are slotted so that may be the reason...
I just think its kind of retarded to put dimples in the friction surface of a rotor when most every other rotor on the planet has minimum rotor thickness stamped on the outer edge. If you have the equipment to turn rotors, you have the equipment to measure their thickness and tell they shouldn't be turned...
Old Mar 22, 2009 | 09:49 PM
Quickywd01's Avatar
What confuses me is why the rotor with dimples has no brembo stampings on the side while the rotor with out the dimples does have brembo stamped on it.
Old Mar 23, 2009 | 06:48 AM
Quickywd01's Avatar
I called brembo at 17347375823 and I was told that the "easy check" rotors have "notches" so that you can check when the rotor is worn out. This is the stupidest thing I have ever heard. That's what micrometers are for. I was also told that depending on where the rotors are made they may or may not be stamped with brembo on the side. I hope these are better than the cheap rotors at parts stores because it doesn't sound like it. Can't wait till next week to put it all on. Thanks everyone for your help.
Old Mar 23, 2009 | 06:59 AM
Norm Peterson's Avatar
The dimples may be there in order to assess rotor thickness without having to pull the wheels. Not for determining how much you might still be able to cut. That would benefit periodic state inspections and could also keep individuals from being sold rotors unnecessarily.
Norm
Old Mar 23, 2009 | 09:25 AM
Matt93SE's Avatar
STFU n00b!
Yes. The dimples help the 'average Joe mechanic' keep his own car up and running vs. having to pull the rotor off and take it to a shop or parts store to check the rotor thickness.
MOST people do not have a way to properly tell rotor thickness.
It's easy enough to remove our rotors to check, but some others (Honda, early Z, Chevy, etc) are a royal PITA to remove because they're integrated with the wheel hub and can't be easily removed from the car to check.
The dimples are a really good idea actually.
And yes, the slots in most aftermarket rotors are usually about the same depth as the rotor's minimum thickness. when they wear the slots off, it's time for new rotors.
Old Mar 23, 2009 | 12:36 PM
mist max2000's Avatar
they are prob both brembo.. you got one old product and one of their newer products in tersm of shelf life..... i would still bring them back and want 2 of the same for peace of mind..
Old Mar 23, 2009 | 09:25 PM
Matt93SE's Avatar
STFU n00b!
Every Brembo disc I've ever bought has had brembo engraved along the outer edge.
Old Mar 24, 2009 | 06:46 AM
Quickywd01's Avatar
When I called I was told not all of them have it depending on where they were made. Seems kind of cheap not to have it on there for a company like brembo. Makes it seem like a made in china product.
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Socalstillen
Sep 26, 2015 12:01 PM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
