Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Clarification on Recentering Rear Beam
Old Apr 2, 2009 | 05:47 AM
Puppetmaster's Avatar
I'm doing this because I'm dropped about 2" (I know, I'm beyond the no-go point on the camber curve for these cars) and my driver side rear sits lower than the passenger side and even the driver side wheel looks more tucked, ie. it looks like it has -5mm offset than the passenger side.
Here's what Larrio posted a while back:
Originally Posted by Larrio
You have to re-center the rear beam. Basically due to the linkage on the rear beam, our solid axle pivots upwards and to the right side under compression.
Now the bushings and such were designed for a car at stock ride height. When you lower the car, you start to deform and constrict the bushings since the suspension angle is changing in relation to the chassis. In the FSM you will find segments on how to re-align the beam. Take a peak next time when the car is on a flat surface and you will see the bushings are bent sideways
What you have to do:
1. measure your rear vehicle ride height
2. jack up the car and place jack stands
3. unbolt the bottom bolts holding your rear shocks to the beam
4. loosen the bolt going through the bushing on your beam (there is one on each side, two total)
5. jack up the beam until it is at the ride height you measured earlier
6. tighten the two bolts you loosened
7. tighten the rear suspension bolts back on
8. lower and drive around
you'll find the rear end of the car will feel awesome because the bushings are not binding anymore and the car won't rub either
My understanding (and this is where I need to be corrected) is that you are essentially raising the beam to where it should sit relative to the lower-than-stock suspension components and then resecuring the lateral link at that point in order to unbind the bushings and level the suspension components.
This is where there is a void in my understanding. The FSM says to raise the beam until the control rod and lateral link are on the same horizontal plane as the beam. But will they still line up properly if I have a lower than stock drop? Isn't that "calibrated" for stock ride height? Or will this leveling still be possible because you've loosened all connections for the components to reposition, thus the term "recentering" the beam? I'm under the understanding that there is only ONE way these components will be on the same plane, and that is at stock ride height.
Here's the diagram for reference.
Sorry if this will be obvious when I actually do it. But in the meantime, I'm sure others might benefit from this discussion.
On a less technical note, any suggestions on good, precise ways to measure the ride height? I was thinking after I pull the wheels off, I'd just measure the distance from fender to hub or something.
Old Apr 2, 2009 | 06:17 AM
Prophecy99's Avatar
word, good collation of the scattered info on this topic thanks.
Old Apr 2, 2009 | 06:24 AM
Prophecy99's Avatar
some pics from an older thread
from the thread http://forums.maxima.org/5th-generat...rear-beam.html
Originally Posted by LA02MAX
alright people, I got some pictures. It's really not that hard once you just get under your car and look, so hopefully this will help
This is looking toward the front of the car. (toward the left)
Here's a closeup of the bushing:
This is looking toward the front of the car. (toward the right)
And a closeup of the bushing itself:
Hopefully these are correct. I'm sure irish can confirm it. I haven't done it myself, but eventually I'll get around to it.
Old Apr 2, 2009 | 06:35 AM
jeff5347's Avatar
Puppetmaster, i recentered my RB as i noticed my driver side tucked in quite a bit more than the pass once i was lowered on sprints. what i did was measure from the center off the wheel to the fender. So when i had the wheel off and the rear beam jacked p i just jacked up until the center of the hub was the same distance from the fender. I did notice a ride quality difference. since the rubbers were not bound any more the car felt as little soffter in ride but like a bit more body roll due to no binding anymore. i DID NOT notice any diff in the clearance of the fender in relation to the wheel. the driver side stayed tucked in, maybe it moved .5 mm but nothing noticeable.
Old Apr 2, 2009 | 06:36 AM
Thanks Prophecy. I never saw that thread.
This post was helpful.
Originally Posted by MorpheusZero
While I haven't yet performed the procedure, I think the whole point is that the positions of the bolts on either end of the panhard link aren't fixed. You loosen up the bolts to allow them to adjust in their elongated holes while you jack the beam up and keep it centered, then crank 'em back on in the positions which keep the beam centered at normal ride height for your suspension. You don't have to get custom bushings or break out the welder, Nissan has already made it adjustable.
The funny thing to me is that there will actually be less lateral movement per suspension activity when lowered than when at stock ride height.
One more thing: because of the design of the links, the only point that's fixed in the model is actually the center point (where the link that branches off the panhard link meets the beam). This design allows for less lateral movement than a traditional panhard rod design. The other connection from the panhard link to the beam has a bushing specially designed to allow for plenty of play.
http://forums.maxima.org/4890327-post66.html
Old Apr 2, 2009 | 07:02 AM
Thanks for the feedback. I'm fine with all that, I just want to do it right.
The looser feel I can deal with because I'll just stiffen up my coilovers and I am also looking at getting stiffer springs all round anyway. The slight wheel "tuck" relative to the passenger side is a secondary thing I can live with because I'm not getting any prizes for looks anytime soon.
Old Apr 2, 2009 | 11:29 AM
Deckdout2's Avatar
Play with my balls
This is great info. Maybe this will fix the rear end wagging I get as well. Also, I've hit a pothole a couple of times with the rear driver's side tire, and it makes a disturbing sound. Like the beam is not tight on that side, or that my strut bolts up top have backed out, and the strut is moving down and slapping against the car when the tire meets the ground again. Doesn't sound good at all and the rear beam axle is a new one from my donor car. I'm sure it's installed correctly and all the bolts are tight. I'm going to have to check my top strut mount and make sure those 2 bolts are on tight as well.
Will have to do this recentering though. Thanks.
Old Apr 2, 2009 | 11:31 AM
Deckdout2's Avatar
Play with my balls
Also, I hear you on my driver's side having a higher offset then the passenger side. I thought it was me and something I did, but glad to see I'm not the only one. I wonder why this is.
Old Apr 2, 2009 | 05:16 PM
PulsarGTS's Avatar
I tried this a few months ago, it does get the rear MORE centered, but not perfect. its not obvious that the left is set in anymore atleast. Ive heard people say that the rear get looser and softer when centering the beam but I added my swaybar at the same time so i cant comment.
Old Apr 2, 2009 | 05:22 PM
IHAVEA2KMAXIMA's Avatar
So when you put stock back on, you have to center it again then?
Old Apr 3, 2009 | 05:44 AM
essential1's Avatar
My axles cry for mercy...
I experience this same exact sound with my coilovers. Its ONLY on my rear passenger side though. I always check and recheck that everything is tight. But, i still get it.
When I get around to it, i'm gonna remover the tophat assembly and figure it out. I believe it has something to do with that . It seems like there may be a very slight bit of play in it.
As to the topic at hand though. I have to also get around to recentering my RB too. Either that, or just put a small spacer on the driver side.
Old Apr 3, 2009 | 06:10 AM
Deckdout2's Avatar
Play with my balls
I'm glad to know that I was not the only one with this issue. I swapped out the RB from the donor because my studs in one of the hubs were screwed up from me trying to install spacers with extended studs. The knurl didn't grab completely when I put the wheel back on and when I went to go remove the lug nut it kept free spinning the stud. Started running out of ideas and took an impact driver to it and finally after a couple hours and some twisting and bending, I finally got the lug nut off. But after all that abuse to my hub, it just widen the hole and no stud would bite down. I just replaced my whole axle with the donor one, and that's when all that noise started. I need to look into this myself at some point when I get some time. Just doesn't sound safe at all.
Old Apr 3, 2009 | 05:22 PM
I did the recentering procedure today and was able to get the lateral link to be on the same plane as the beam, the control rod however, with my drop at least, went to the angle / once I had raised the beam to my measured ride height. This was what I was initially concerned about. From what I can tell, it is not physically possible to get the control rod to line up with the lateral link and beam AND maintain my current ride height.
For procedural notes, I put the car on stands took the wheels off, loosened all the appropriate nuts, raised the beam using two jacks on either side (because I didn't want to remove my RSB), measured both sides, and tightened everything back.
I haven't driven it yet, but I'll post again later if there are any differences.
Old Apr 3, 2009 | 07:37 PM
Okay, this may be a worthless opinion but I went out for a quick spin and maybe it's the placebo effect, but the ride quality definitely seems to be better in the rear in terms of absorbing bumps and it actually feels like it is turning flatter.
The driver side tuck has not gone away (I measured to be doubly sure and it's about 3/8 to half an inch further in than the passenger side) but like I said, it doesn't bother me that much, so no, I will not use different sized spacers to make both wheels flush.
Old Apr 4, 2009 | 10:47 AM
Deckdout2's Avatar
Play with my balls
Thanks for the review Joel. So this is a worthwhile adjustment to make is what you're saying?
Old Apr 5, 2009 | 08:54 AM
Prophecy99's Avatar
sounds good thanks for the input, I may just leave mine alone for now.
Old Apr 6, 2009 | 05:16 AM
Yes, definitely worthwhile.
On my drive into work today, I could feel that ride quality is improved and on the long sweeping ramps, more importantly, there's much less bump steer if the ramp is bumpy. It just absorbs the impact much better.
But on these higher speed turns, I now feel what people are saying that the rear isn't as tight and there's more lean. Not sure why I felt differently the other night; maybe its because I only look short sharp turns at less than 40 mph.
Old Apr 6, 2009 | 10:20 AM
Deckdout2's Avatar
Play with my balls
I wonder if there is more/less of a chance now for the rear end to swing around for someone equipped with a RSB. Since I've had these Tein SS's I haven't found the need to add one back on. I think you have one on yours still. You should remove it and then do a comparison with just the coilovers with and without the RSB. Maybe reentering the RB puts it back in that scary realm again. I have not had my rear swing out on me before and I hit corners pretty hard sometimes.
Old Apr 13, 2009 | 01:43 PM
jeff5347's Avatar
i dont think your off on your assumption. I noticed when i did mine it took the bumps better. Hahah made it feel more cusiony and i was like where did the sport feel go. But yea it def softens ther rear up
Maxima.KsA
May 15, 2020 04:14 PM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
Johnny9595
Sep 3, 2015 05:18 AM
