Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
BBK Options - Clarifications
Old Aug 2, 2009 | 06:14 AM
k2a2b's Avatar
What I understand:
Both Matt and Jeff's kits use 30mm 300zx calipers via relocation brackets.
Matt's kit utilizes 6th gen rotors.
Jeff's kit uses redrilled or spaced cobra rotors.
Question:
Can either of these kits accommodate 300zx rotors?...Or the two piece 300zx rotors automax95 is selling? (I realize he is also selling 2 piece cobra's).
Thanks in advance.
Old Aug 3, 2009 | 11:35 AM
Fr33way™'s Avatar
Wild for Width
If you were to use Z32 rotors you would not need a relocation bracket, just the conversion brake lines. The bracket is to fit the bigger Cobra rotor (hence the BBK).
Old Aug 3, 2009 | 11:39 AM
Fr33way™'s Avatar
Wild for Width
I'll drop this here as well:
Originally Posted by Matt93SE
They're cheap because they're not much better than the stockers.
What year car?
the stock 2000-2001 rotors are larger diameter than the Z32 rotors and 26mm thick.
02-03 are an inch larger, but 24mm thick.
04-08 are 12.6" x 28mm.
the only good thing about the setup you have is the Z calipers, which have better selection of high performance brake pads.
Old Aug 3, 2009 | 01:48 PM
k2a2b's Avatar
Thanks!
Old Aug 3, 2009 | 06:58 PM
1handicap's Avatar
Any reasonable upgrades for the 5.5 Gens?Or does anyone REALLY know how to fix the "loose fitting" pad issue.This happened when i had to replace the rear calipers because one would not screw back in.I think it is a Wagner remanned caliper.Even took back to my dealer where there they assured me that it was the fault of the aftermarket brake pads.After $400 and new pads and shim kit,it is doing it again after 2 months.Sounds like something is rolling around in the trunk when you hit a bump.REALLY FRUSTRATING!!!!!!!!!
Old Aug 4, 2009 | 12:21 AM
Fr33way™'s Avatar
Wild for Width
I'm going to say this as nice as possible but you are posting this in the wrong place mate. Notice the thread title.
That sounds more like an upper strut mount issue with your rear suspension. For way less than 400 bones I'm sure you could have a local orger take a look at it. Check your regional forum (link).
Old Aug 4, 2009 | 08:32 PM
1handicap's Avatar
New to the board here sorry.It is not the strut mount.The noise goes away when you pull on the e-brake,just like the TSB states.Have been all over the board and back looking for threads or upgrades for rear brakes.
Apr 16, 2020 05:15 AM
Mar 12, 2020 12:06 AM
Robert Schneeweis
Jan 11, 2017 06:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
Redfox
Sep 28, 2015 10:41 AM
