Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Megan racing coilovers
Old Aug 15, 2009 | 06:27 PM
a33i30's Avatar
So, anyone have them? I didn't find any threads , thought I'd see people's thoughts on it.
Old Aug 15, 2009 | 06:30 PM
a33i30's Avatar
Also, how do they compare to D2, Ksport and NEX(the under 1k coilovers).
Old Aug 15, 2009 | 08:22 PM
MoncefA33's Avatar
Taken from NYCmaximas.org:
Originally Posted by K3Y
Megan Racing Coilover*Only For 5th Gens*
Megan Racing Coilovers is also another Coilover built with street tuners in mind. We were able to test this out on a Acura TL 2001, which in many eyes looks almost like the 4th gen. The ride was good enough where you can actually carry a pregnant women in the car, lol. Many car enthusiasts says megan racing is crap, etc etc.. I wont say their crap,, but good enough company that puts out some good stuff When turning , there was a little noise coming only from the driver side, came to find out it wasnt grease'd up as the others. Guess a little fault from the company, but no matter. We took that coilover apart, greased it up, assembled it back on and we were noise free! Great coilovers for street enthusiasts, BUT, only made for 5th gens. Comes with 32 adjustable
More Info
The Megan Racing Street Series Coilover Damper Kit is excellent upgrade to your street car. Featuring 32 levels of damper force and full-height adjustment, the Megan Racing coilover damper kit will enhance your car's handling performance.
The adjustment of the damper is simple with a built-in **** at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired.The height adjustment is made easy with CNC-machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
On many car applications, the Megan Racing Coilover Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber (see specifications table below). Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height, improving your car's handling, predictability and tire wear.
Megan Racing coilover damper kits are manufactured for quality and durability. The springs that are part of the coilover damper kit are constructed of SAE-9254 cold-wound steel and tested over 500,000 times by compression inspection. These have deformation of less than 5% and high strength sophisticated surface coating. Megan Racing stands by its products with a 1-year limited warranty
Megan Racing Street Series Coilover Damper Kit Features:
- Pillow Ball Upper Mounts w/ Camber Adjustment (Front Only)
- Rubber Dust Covers
- Adjustable Ride Height
- Aluminum Brackets
- All Hardware is Included
- All coilover damper kits come with 1 year manufacture-defect warranty
32 Levels of Adjustment:
- 1-8: Suggested for track use.
- 9-16: Suggested for mountain/aggressive use.
- 17-32: Suggested for common street use.
Price:
871.50[/b]
I Want to Buy
http://www.raceinspired.com/pc-9944-...2000-2003.aspx
http://www.turbowholesale.com/produc...5&cat=0&page=5
That would be a start, they look pretty good actually.
Old Aug 21, 2009 | 01:15 AM
a33i30's Avatar
Thats all on these? Interesting how no one has installed them on a max yet.
Old Aug 21, 2009 | 06:02 PM
DAVE Sz's Avatar
Hooooooonda.....
they look like ksports, just different colors. They will last as long as you clean them every week or two to prevent rust...
Old Aug 22, 2009 | 02:58 AM
MorpheusZero's Avatar
Yeah, they compare to k sport etc. Don't get any of them.
Old Aug 22, 2009 | 04:56 AM
ShippedOut's Avatar
I heard good and bad from Megan. I have Megan Racing Springs on my car and the ride is stiff, you feel practically every bump on the road. They also have the stiffest spring rate compared to all the others.
All and all I would get something else like the JICs or even BC because Megan just makes copies of other peoples products so it won't be the same.
BkGreen97
Apr 2, 2016 05:47 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Garrettz459
Sep 28, 2015 02:50 PM
followthadollar
Sep 23, 2015 08:31 PM
