Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Suspension swap feasability
Old Sep 22, 2009 | 03:07 PM
k2a2b's Avatar
I know this is a crazy idea...
Anyone know how feasable it would be to swap a 3rd gen rear suspension into a 5th gen?
I understand it would require a lot of doing...anyone think it's worth it? for the irs and bbk option?
Old Sep 22, 2009 | 03:26 PM
Matt93SE's Avatar
STFU n00b!
I'd say you're better off doing custom than trying to do a swap. The biggest issue you're going to face is the rear struts/shocks. The strut towers in a 3 gen are very tall- they go to near the top of the back seat.
pic for reference: http://blehmco.com/imagens/rstb/rstb4.jpg
Thus, you'd have to either rebuild the entire rear unibody of the car, or figure out a custom spring/shock combination that would work.
You would also have to find a way to make the 3 gen rear subframe work on the car, and that would be no easy task. By the time you've done all of that, you might as well just do a complete custom suspension back there and rid yourself of the weak links on the 3 gen rear suspension as well.
(The 3 gen suspension is better than the 5 gen, but there are many other designs out there that improve on the 3gen as well.) Might look at the 02-03 Altima rear suspension design, or the 6th gen.
Both of those use a rear drum-type parking brake which is the same size as the 300ZX and maybe the 350Z rear drum stuff. Thus using a larger rear disc is as simple as finding a setup that works on one of those cars and making a caliper relocation bracket. no parking brake hassles to deal with.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
