Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
What would cause my rear to feel like its moving side to side over bad roads?
Old Dec 8, 2009 | 02:15 PM
shadyonedeath's Avatar
4th gen
illuminas
nuts and lugs all rechecked and tight.
Feels like it just started up, if im going over bumps or bad roads, the rear seems to "fish tail" .
Old Dec 12, 2009 | 07:41 PM
hotimportnight9's Avatar
ive got the same problem i would like to know what causes that problem but i have all factory shocks and struts, soon will have tokico install
Old Dec 13, 2009 | 12:35 PM
rroderiques77's Avatar
Demodded and Forgotten
Blown struts will cause it.
Also could have worn trailing arm bushings
Old Dec 13, 2009 | 06:45 PM
irish44j's Avatar
retired moderator
yes, and yes.
also check your tire pressures. When it gets cold, the air gets smaller and the tires get squishier
Old Dec 14, 2009 | 09:26 AM
Matt93SE's Avatar
STFU n00b!
could be worn out bushings in the scott-russell link as well...
Old Dec 14, 2009 | 11:01 AM
how hard is to replace the bushings?
Old Dec 18, 2009 | 10:39 AM
asand1's Avatar
+1 The others are possible, but the S-R link is whats responsible for lateral control.
Old Dec 20, 2009 | 08:24 PM
Matt93SE's Avatar
STFU n00b!
The trailing arm bushings are also known to die eventually, and will result in a wandering car as the rear end alignment changes. I've seen a few 4 and 5 gens with bad bushings, and the back end drives weird.
Huttig2009
Sep 25, 2015 03:31 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
BobMax
Aug 15, 2015 12:35 PM
laparka66
Aug 6, 2015 09:36 AM
