Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Ground Control: Different strut versions?
Old Feb 2, 2010 | 07:03 AM
MOHFpro90's Avatar
I have been looking at some ground controls for a while, and found a set made for the AGXs. Seeing as how I am going to use Koni's with them, I am trying to determine the differences between the versions of the GC's. I would venture a guess that the spring seats and mounts are slightly tailored to each make of strut, but how much? Are there any known problems using a different version of Ground Controls on a set of struts? The part numbers are different, as seen in this store here. Any insight?
Old Feb 2, 2010 | 04:23 PM
Matt93SE's Avatar
STFU n00b!
The issue is that they run a slightly different bore on the strut housings with different manufacturers.
What you need to do is measure the diameter of the struts you're going to be using, and then call CG and talk to one of their tech guys to make sure you're getting the right thing. they may send you to a dealer after you've verified the proper parts, but I've always just bought my stuff directly from GC over the phone.
Old Feb 3, 2010 | 07:30 AM
DrunkieTheBear's Avatar
Turbo'd Saab
hmmmmmm...thats a good idea...maybe I could get some Ground controls that fit on my Grand prix struts.....
Old Feb 3, 2010 | 07:38 AM
PininFarina456's Avatar
GC makes many applications from stock struts to all the aftermarket shocks.
The perch is the biggest difference between each. I'd give GC a call and tell them you have an AGX set and are getting Konis, if its a perch, I'm sure you can just buy it from them.
GC has some of the best customer service out there...
Old Feb 3, 2010 | 08:13 AM
ajcool2's Avatar
Good info.
Old May 8, 2010 | 07:20 AM
Redmax's Avatar
Redlinemax Owner
Very good info!
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
