Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Rear Negative Camber
Old Oct 16, 2010 | 11:05 AM
dubsonmax's Avatar
Alright so I already know the effects that negative camber in the rear can cause but this car is no longer a daily driver. I'm trying to get about a 5-7 degree negative camber without bending the rear beam. What would be the best way to do this. Yes I know the rear camber isn't adjustable but is there anyway to do this. Google is no help today.
Thank, Rick
Old Oct 20, 2010 | 09:16 AM
Dark_man_x's Avatar
alot of guys with rear beams use shims behind the hub to get camber in the rear.
Old Oct 21, 2010 | 03:08 PM
dubsonmax's Avatar
Where exactly behind the hub, on which bolt?
Old Oct 21, 2010 | 04:02 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
Thank, Rick
You can't change the negative camber on the rear of the 4th/5th gens unless your bending something, cutting/welding the beam up, or replace the beam with IRS.
The shim trick only works if the rear hubs were removable, VWs with rear beams and removable hubs are a good example. You can shim some VWs for rear toe/camber adjustment. On the maxima beam the hubs are part of the beam and only the wheel bearings are removable, so they can't be shimmed.
Old Dec 16, 2010 | 08:52 AM
speedymax99's Avatar
So nothing is adjustable and you don't want to bend the beam. Good luck!
Old Dec 16, 2010 | 01:10 PM
MrDicks95SE's Avatar
Offset Is Everything.
beam bending party.
Old Dec 18, 2010 | 07:04 AM
Matt93SE's Avatar
STFU n00b!
5-7 deg of camber is just stupid.. if you do that, you're going to kill yourself.
on my dedicated track car I only run -3.5 and that's still a ton of camber.
but no, you can't adjust tow or camber on a 4/5 gen without bending the rear beam.
Old Mar 25, 2011 | 10:15 AM
doublea's Avatar
Is there any available instruction on how to bend the rear beam ? Not that I necessarily want to do that but I'm curious to see how they do that.
Old Mar 25, 2011 | 10:22 AM
phatboislim's Avatar
Old Mar 25, 2011 | 01:06 PM
doublea's Avatar
I'm not to sure what this quote & no answer mean, but I guess I have to take it with humour...
Old Mar 26, 2011 | 04:48 PM
ajm8127's Avatar
I think when people reference "bending the rear beam" they mean taking out the factory 1 degree of toe in. Setting the beam to 0 toe improves the oversteer situation significantly, or so I've read. Bending the beam has nothing to do with camber, but toe.
I know that doesn't really answer your question, but that's all I got. I think Joe (98SEBlackMax) has his beam bent. Maybe he can chime in.
Old Mar 29, 2011 | 04:53 AM
99greddymax's Avatar
oni camber ftw?
matts95max
Apr 23, 2025 10:44 AM
GregL65
Jan 17, 2020 08:01 PM
bbsitum
Sep 11, 2015 04:55 PM
adamgalazka
Sep 8, 2015 01:27 PM
