Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
q45 caliper relocation bracket
Old Mar 4, 2011 | 12:10 AM
Brandon8965's Avatar
does ANYONE know of someone making or selling the relocation bracket for a 4th gen with the q45 setup.. it's a bit of a hassle having to find someone to shave 8mm of the outter diameter everytime i have to get new rotors.
Old Mar 4, 2011 | 07:15 AM
BLKonBLK98's Avatar
use s14/z33 track brackets w/ 6g rotors.
Old Apr 25, 2011 | 07:48 AM
Flava_24/7's Avatar
Boosted Panda
Would this work with the Z32 calipers as well?
Something like this....
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old Apr 25, 2011 | 08:39 AM
mista0406's Avatar
Jeff92se here on the org I think still makes the dog bones to fit the brakes
Old Apr 25, 2011 | 10:00 AM
Flava_24/7's Avatar
Boosted Panda
But those are for the Cobra rotors correct?
I know Matt sold blehmco, but curious if they still sail the brackets.
Will have to PM him
Old Apr 25, 2011 | 12:42 PM
mista0406's Avatar
Will have to PM him
It was said and I was under the impression, and don't quote me, that the ones Jeff sells works with both Q45 and the Z32 calipers and that rotor didn't matter. Brackets were made so the calipers would align properly, please correct me if I'm wrong.
Old Apr 25, 2011 | 01:57 PM
Maximathug's Avatar
Brackets
Jeffs brackets can be used with the Z32 and the Q45 calipers, but are made to only be used with the Cobra rotors.
Old Apr 25, 2011 | 02:06 PM
Jeff92se's Avatar
I'm needing a caw
Will have to PM him
Correct. I do have a few sets in stock still.
If you want to use the smaller Q rotors with the Q45 calipers, it's easier to get the rotors shaved. The amount of adjustment is so small that it would be pretty hard to design a bracket that accomodates only a few mm while maintaining the same nissan rotor offset.
Old Apr 25, 2011 | 03:35 PM
ducz24's Avatar
+1 would these work?
Old Apr 25, 2011 | 04:16 PM
Jeff92se's Avatar
I'm needing a caw
Bolt holes are ever so slightly off as the FWD nissans does not = RWD nissans in caliper/rotor fitments. It this difference that makes us have to shave the rotor in the 1st place. This might work to get a bigger rotor but you'd still have to shave the bigger rotor.
Old Apr 26, 2011 | 09:47 AM
k i have your dogbone brackets jeff but i need to know if i absolutely need some hub rings... i keep seeing yes and no in all this research
Old Apr 27, 2011 | 01:37 PM
Jeff92se's Avatar
I'm needing a caw
It was too hard for my machine shop to make those hub rings. Since then, Automax has been redrilling a set of Nissan sized stud holes in the Ford Cobra rotors. I haven't read any problems from centering the rotors using this method. So this is the solution I point everyone too.
Old Apr 29, 2011 | 08:41 AM
automax is a member here or a place?
Old Apr 29, 2011 | 09:11 AM
Jeff92se's Avatar
I'm needing a caw
He's a member here and has the rotors for sale in the group deal section
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Calabar
Oct 5, 2015 09:57 PM
imported_Nismo_max
Sep 21, 2015 07:24 PM
